Need to get a bale spear
   / Need to get a bale spear #1
PROFarms
Devon, England
International 444, Yanmar YM169d, Cub Cadet
Hi guys. So the time if year is coming when we will need to start putting out bales for the animals. This year is the first year we have had rounds done so I done actually have a bale spear to move them from the stack our contractor made out to the feed pens.
Having had an initial look it looks like it's going to be cheaper to make one myself - as most things seem to be!! Anyway I've been looking at buying one of the spikes to put on it and there seems to be so many different sized ones from 800mm up to 1500mm. We will e moving mostly 4' bales but one or two 5' bales. What sized spike would be best? Would about 1000mm be ok or could I get away with 800mm?
   / Need to get a bale spear #2
I have a 42 inch (1067mm) on my 3 point hay spear. Works fine on 5' rolls. Same on the spear on the FEL.
   / Need to get a bale spear #3
The most common length around here is 48" plus or minus 2. Doing the math, 48" = 1219 mm. I wouldn't even consider the 800mm spear.
   / Need to get a bale spear #4
Bought a brand new 3pt spear (42" plus 2 anti rotatation tines) for less than $300 new a few years back.
Could have bought the spear for $120 and built the rest...but doubt I could have done it as nice and as cheap....
   / Need to get a bale spear #5
When working with rounds it's better to have at least two (2) spears. It doesn't matter if they're FEL or 3PH mounted, two will give you more control of the round & prevent them rotating when picking them up and moving them.
PROfarms, you mentioned that your rounds have been stacked. Are you going to be using a FEL to move them?
   / Need to get a bale spear #6
We got a 4' one, no name special , probably speaks Chinese with SSQD last year from local farm dealer $500. How we managed to roll those damned things prior I have to just wonder. I was going to make one but figured up it would be a major PITA and not save all that much in the end. The only thing it lacks is that the spear is part of it being all one piece. I can live with that because I can weld. I did make a crude 3 pointer up years back and the rod bent all too easily. By the time you get one buying the spear it's hardly worth making up the whole rig as long as you can find one for a decent price.
   / Need to get a bale spear #7
WOW. Personally I wouldn't get a spear that wasn't bolted on.
Not for the weight of the rounds but for those stupid decisions of "It's too much trouble to put the forks on... I'll use the spears. What could go wrong?" :duh:
Disclaimer: Didn't happen to me but to a friend, however it was a lesson learnt.
When working with rounds it's better to have at least two (2) spears. It doesn't matter if they're FEL or 3PH mounted, two will give you more control of the round & prevent them rotating when picking them up and moving them. PROfarms, you mentioned that your rounds have been stacked. Are you going to be using a FEL to move them?
Yes I will be using a FEL to move them. Contractor stacked them back in the summer for me though
Bought a brand new 3pt spear (42" plus 2 anti rotatation tines) for less than $300 new a few years back. Could have bought the spear for $120 and built the rest...but doubt I could have done it as nice and as cheap....
I can get a 42" spear with all the fittings then a 24" anti rotation tine with the fittings. Can get the two of them together for $68 plus a few $$ on the metal. Probably have to make one in the end because we have custom loader brackets so would need to adapt anyway!!
Otherwise I could buy one with no anti rotation spear for $275
   / Need to get a bale spear #10
If for loader, get a chain on spear. No messing with brackets and if you are only moving a few bales, it will work great. I moved many bales over the years with one. Not as nice as a true quick connect but no tools needed to mount and on and off in a minute,
2018 FORD F150 Ext Cab 4X4 Pick-up Truck (A53422)
2018 FORD F150 Ext...
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A52377)
2014 Peterbilt 320...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2018 JOHN DEERE 410L BACKHOE (A52705)
2018 JOHN DEERE...
2013 Volvo BL70B (A47477)
2013 Volvo BL70B...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
