need to drain and refill hydraulic fluid in MF 135 - how?
   / need to drain and refill hydraulic fluid in MF 135 - how? #1
joel.smith1969
Noticed on my new 135 that the hydraulic fluid is white, which I am guessing means it has water in it. Question is, how do I drain and refill the fluid? will the tainted fluid cause any long lasting problems? Any advice welcome. Thanks!
   / need to drain and refill hydraulic fluid in MF 135 - how? #2
Yes, that would be water, 3 drain plugs, tranny, hyd, and diff, this is a common reservoir filled through the large plug to the left of gear shifter, takes about 8gals of a good trans/hyd/diff oil to MF specs M1129A, i use MF Permatran 3. Lower the quadrant controls when draining to drain the lift cylinder The filter is accessed through the cover plate with the PTO lever, unscrew the large flanged retaining top and remove the whole assembly, if in good shape clean and replace. You can flush out the system by dumping in 3gals of diesel and gently driving around for a few minutes, drain well and refill slowly allowing the oil to migrate to the back end
how do you remove the filter assmebly? As for the wire, just cut it or is there a way to remove it so that it can be refastened? Thanks
   / need to drain and refill hydraulic fluid in MF 135 - how? #4
Cut the retaining wire (you can use a piece of bare copper electrical wire to replace it), the filter sits inside a cup with a similar cup on top held down with the large "wing nut" bolt, unscrew the cap and try to lift out as one unit so as to avoid dropping crud into the pump inlet.
   / need to drain and refill hydraulic fluid in MF 135 - how? #5
Then check/replace your shifter boots, & draft control spring boot. That water is getting in somehow. Those are the common culprits.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2019 FORD F-250 SUPER DUTY (A52472)
2019 FORD F-250...
NEW Wolverine Skid Steer Bucket Root Rake Attachment 31'' (A53002)
NEW Wolverine Skid...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
3 Point 36'' Lay Off Three Rows Plow (A51573)
3 Point 36'' Lay...
