Need to dig a 5x5x6-foot hole - can I do it with the grapple bucket?
   / Need to dig a 5x5x6-foot hole - can I do it with the grapple bucket? #1
MikeOConnor
Western Wisconsin
Two Power-Trac 1850s (preferred for mowing and grapple-bucket clearing type work on really steep hills). Kubota M680 for snowblowing, grading, bucket.
Ok, this is the nuttiest project I've taken on here at the farm -- putting up a 100' radio tower for ham-radio and microwave data antennas.
I've got me a bead on a nifty 100' self-supporting tower that needs a pretty darn substantial base -- and I'm thinking about using the PT to dig the hole.
I don't know beans about dirt work. I use the grapple bucket to move stuff around rather than dig holes. Hence my question to y'all. If you were digging a 5x5 foot hole that's six feet deep, how would you approach it? My thought is to dig it "from one side", basically making a ramp down that side and digging out the hole using the ramp to get the PT down there.
Am I on a fool's errand here? or is there a better approach? or should I just go rent a backhoe and use the proper tool for the job...
   / Need to dig a 5x5x6-foot hole - can I do it with the grapple bucket? #2
Well you could do it that way they dig swiming pools around here with skid steers using that technique. The problem is you are going to have to shore up the ramp side before you can pout the concrete. If you used a back hoe you could probably get the hole square enough that you would not have to shore it up.
   / Need to dig a 5x5x6-foot hole - can I do it with the grapple bucket? #3
I dug a tree stump out that way with my 180, but it was not 6 foot deep. The problem you will have is backing out of the hole once the tires load up, and start to spin. For a 6 ft deep hole you would need one very very long ramp to be able to back out. Especially with a load of dirt in the bucket. If it were me I would go with the back hoe, much quicker less mess. Just my thoughts. ;)
   / Need to dig a 5x5x6-foot hole - can I do it with the grapple bucket? #4
I kinda think you answered your own question in the above part of your qoute. Time wise and when doing this you have to go to undisturbed ground before pouring any type of a footing which makes me in favor of the BH. Another words one can't put fill back in without having the proper compacting done and around my area an engineer needs to put a stamp of approval on it before the building permit will be signed. If I'm correct, a tower of that high has to have many other permits regading lights etc. :)
   / Need to dig a 5x5x6-foot hole - can I do it with the grapple bucket? #5
Isn't this the time to apply the money you'd spend on renting a backhoe to help pay for the mini-hoe attachment for your PT?
In my "Rock-B-Gone" thread, my second set of photos show a hole I dug that's 5' deep, and I had to dig a little bit of ramp to get down that far. I could've gone 6' with a foot lower ramp and that'd only be 2' of support if I were to fill the hole with concrete. Your PT may be able to dig deeper than a 422 with the hoe?
Renting a backhoe will make the nicest hole and do it in the quickest time. Around here they are $200/day + transportation ($60) if you don't have a capable trailer and live too far to bobtail. That's about a quarter of the price of the 422 mini-hoe less shipping.
I tried digging with my grapple bucket, like your question. Did a horrible job even tho the ground was relatively soft and rockless. Ended up using the hoe to break up for the ramp, then scooped it all out with the LMB. Then dug and scooped the hole with the hoe.
This was the first time I'd tried digging with the grapple bucket. Maybe it was my technique, but I don't think I'll try it again. I expected it to work better than it did.
[on edit] THIS was ANOTHER time I wished I'd ordered the 12" bucket for the hoe along with the 9" that came with it. I didn't know it was available at the time I made my PT orders.
Phil
   / Need to dig a 5x5x6-foot hole - can I do it with the grapple bucket? #6
How does this blend in with your planned taking of the property back to nature?
LOL...
it's not entirely consistent... but hey, we've planted 150 acres of prairie, cleared another 20 or so of existing prairie, fixed up about 30 acres of woods and another 15 of wetland.
So this is my spousal reward for helping Marcie with all those projects. :)
Plus, the radio/microwave gear is going to be solar powered. Here's a link to the project on my blog;
Mike O’Connor » Remote transceiver and antenna
Ok gang -- you've convinced me that this is NOT a good project for the grapple bucket. Yippee! I get to try running a back-hoe. I think I'm gonna rent one -- I don't think I'll get to dig too many more holes like this one.
Thanks!
   / Need to dig a 5x5x6-foot hole - can I do it with the grapple bucket? #8
I bought Lackender's mini hoe because it can dig 6' instead of 4' which is real important here (20 degrees this morning). I have not been able to try it yet but it looks quite substantial. You might want to consider that as an option. More expensive than renting but you would hopefully have a useful piece of equipment. It would definitely take longer than with a real backhoe.
Ken
   / Need to dig a 5x5x6-foot hole - can I do it with the grapple bucket? #9
MikeOConnor said:
LOL...
Thanks!
Don't rent a backhoe. Rent a TRACK hoe, you know... a tracked excavator. I have rented a small bobcat tracked excavator and it did a very impressive job. You won't be sorry.
   / Need to dig a 5x5x6-foot hole - can I do it with the grapple bucket? #10
Mike, I am totally jealous of your life.
If I could afford to give up what I do and do what you are doing (with your property) I would do it in a hearbeat. Saddly I come from Schmuck Stock so there is little chance of an inheritance or other large windfall. And for what I do I feel most of the time it is one step below **** and half as interesting...
That all said, who in the heck uses a ham radio these days? I mean I would think more people use cans and strings that that technology ;-)
Also, in your blog do you guys have a sat photo of the whole property? Looks amazing...
Oh, I totally second kens suggestion on Lackenders. I have not seen my either, but renting when you could buy instead makes much more sense to me...
Carl
2011 Mercedes Benz Sedan (A51694)
2011 Mercedes Benz...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2013 Club Car Carryall 252 Electric Utility Cart (A51691)
2013 Club Car...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
