Need to bore 3-4 ft horizontally for water line
   / Need to bore 3-4 ft horizontally for water line #11
I thought about this, but wasn't sure how quickly it would turn into a giant mess as I'll be in clay at 4 ft
It would be easy enough to dig a short trench in the woods and try it. If it makes a huge mess, fill it up and call it a failure. When I'm digging under other utilities I like to dig about 3' on both sides about a foot deeper so I don't have to lift out any dirt by hand. Just break it loose and rake backwards. I've also driven a 2" pipe under a sidewalk, and ran a water line through it. Ok, not going to lie. I pushed it through with the backhoe because driving it was a lot like work.
   / Need to bore 3-4 ft horizontally for water line #12
I've used a piece of galvanized water pipe, cut at an angle to make a sharp point, hooked to a garden hose. The pressure is low enough that there is not much high pressure blowback. Going about four feet didn't make much of a mess. It took about two minutes to go about four feet.
   / Need to bore 3-4 ft horizontally for water line #16
How about a 30 inch auger that makes a 1.75 wide hole powered by a cordless drill? Just this week I bought one at Ace Hardware for less than $20. Here is one that is only 18" just to show what I'm talking about.
Yard Butler 18in Roto Auger (REA-4) - Bulb Planters - Ace Hardware
Thats a neat idea - I may have to run a line under a sidewalk and that would be really simple and easy. Also like the idea of pushing a pipe through with the backhoe. Glad the OP started this thread!
   / Need to bore 3-4 ft horizontally for water line #17
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2017 Ford Explorer SUV (A53424)
2017 Ford Explorer...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A55788)
2014 Peterbilt 337...
UNUSED LANDHONOR LDH-HT380 STAND ON SKID STEER (A54756)
UNUSED LANDHONOR...
