Need Tire Chains for BX2660!
   / Need Tire Chains for BX2660! #1
Lumberdink
Billtown PA
Anyone running chains on all 4 wheels on a BX2660 with AG tires? This is my first real snow with my BX and Sno-Pro plow and I'm having a heck of a time getting traction. I can hardly make it back up the hill to plow back down. If I plow at an angle, it kicks back out. I have 260 pounds of suitcase weights on the front but it hardly helps. These look like nice chains and it they'll fit the front, I'll order 2 sets.
I'm stuck! Help! :mad:
   / Need Tire Chains for BX2660! #2
What do you have for ballast on the rear?
Well, I started with 130lbs (2 suitcase weights) but moved everything to the front (4 weights). I have a rear blade I could add to the rear. I'm really spinning out and bumming. :thumbdown:
   / Need Tire Chains for BX2660! #4
Its really wet,heavy,deep snow out there today. I had same issues plowing today , so I took smaller bites to get the job done. Normally I dont have traction issues with turfs, but its so deep and heavy stuff its just takes awhile to plow.
   / Need Tire Chains for BX2660! #5
You definitely need to put some weight on the rear, at least 300lbs, more is better. Do you have a ballast box? Getting a set of chains is a good insurance policy and dollar for dollar the chains on the site you linked are a good value. Be sure to purchase the tensioners as well.
I'm in the same boat, my issue is I need some weight up front.
   / Need Tire Chains for BX2660! #7
I'll mention it before someone else does- Kubota does not recommend front tire chains (I thought about it, too) They have another way to discourage their use- the front steering linkage is so close to the rim, chains would need to be lengthened on the inside to fit.
You should definitely run 2-link chains on the rear.
Anyone know if there's enough clearance on the front tires for chains on my BX?
Sorry---our posts crossed. I posted before I saw your reply.
Any other options on the front? Spacers?
   / Need Tire Chains for BX2660! #10
PS---my tires are loaded.
Forgot to add, be sure you are floating the plow blade, otherwise the front wheels will have no place to go but up.
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A53472)
DeeZee Crossover...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
