Need Tips Removing Loaded rear wheels on jd 2520
   / Need Tips Removing Loaded rear wheels on jd 2520 #1
p0peye
southern tier Ny
JD 2520
So I just got a Good deal on a complete set front and rear R3 Turf tires and wheels for my JD2520 in Mint condition for $800. I have Loaded R4s and was wondering if anyone has some tips on removing the Heavy loaded R4s. Thanks By the way how heavy do you think they are my guess is 300#
   / Need Tips Removing Loaded rear wheels on jd 2520 #2
Where do you plan to move them to?
R4's balance upright pretty well, and I had no problem rolling them around (loaded) by myself when I switched them, and again when I added spacers on each of back wheels.
Once you have the tires switched, then move them with your FEL.
   / Need Tips Removing Loaded rear wheels on jd 2520 #3
Pump the fluid out
   / Need Tips Removing Loaded rear wheels on jd 2520 #4
Thank You for the help I don't feel like it will be a problem now. Looks like the rears will be 235.4 plus not as bad as I thought. Thanks Again
   / Need Tips Removing Loaded rear wheels on jd 2520 #6
I've moved loaded 16.9-28s on the 2030, but have not had a reason to tackle the 18.4-34s on the 6415 and hope I never do. Your R4s should be a piece of cake.
Thanks again Just finished and yes it was a piece of cake no problem at all. I was concerned with the loaded tires but it was not a issue.
   / Need Tips Removing Loaded rear wheels on jd 2520 #8
A pump and barrels. Then get rid of that aggressive corroding salt and go with dry tires and cast weights, windshield washer fluid or beet juice.
   / Need Tips Removing Loaded rear wheels on jd 2520 #9
b&d
How did you possibly construe that p0peye's loaded tires had CaCl in them?? I know you hate liquid ballast but COME ON.
RimGuard
2015 FREIGHTLINER CASCADIA DAY CAB (A51219)
2015 FREIGHTLINER...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2016 Dodge Journey SUV (A50324)
2016 Dodge Journey...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
