Oil & Fuel Need tips for 2538 oil change and fuel filter upgrade
   / Need tips for 2538 oil change and fuel filter upgrade
I ordered two of these pans: Amazon.com: Hopkins 11838 FloTool 15-Quart Oil Drain: Automotive. $6.67 each as an add-on item on amazon. I ordered a filter wrench and long funnel to qualify.
I am interested in making a dipstick for the transmission. I'm thinking a 1/8 metal rod, dipped into the transmission to get the current level, before draining.
I'll look at getting a chain clamp and locking zerk coupler.
Thanks for all the help!
   / Need tips for 2538 oil change and fuel filter upgrade #12
Fifteen quarts is just short of 4 gallons. You should check your common sump hyd oil capacity... Once you pull the plug you need to have pails available for the full capacity just in case. Please do not ask me how this can turn sour real fast if you are not prepared..... The mental scars take a long time to heal... :)
D'oh! You're right. Thanks for pointing that out. The transmission is 8.5 gallons, the engine is 1.3, and the front axle is 2.2. Don't know why I thought two 15 quart drain pans would hold all that. Back to amazon. . .
   / Need tips for 2538 oil change and fuel filter upgrade #14
I tried several ways to refill my sump. I finally settled on using a bucket pump stuck into the 5 gallon pail of hyd fluid. With the pail set up on a stool to keep it at a comfortable height. I did not take the cover off the pail, and just stuck the pump part down into the opening [ you can make it bigger if the opening is too small. Then stuck the pipe on the end of the hose into the small opening in the fill hole. I tried to just use a funnel/dump it in slowly, but did not turn out too good of an option. Hand pumping in the contents takes a little time, but you get to oggle the arse end of your tractor whilst you work.... helps pass the time. When done, I put the pump into a clear plastic bag and hang it on the wall. Keeps it clean for next time.....
Amazon.com: Powerbuilt 648772 Lever Bucket Pump: Automotive
2003 Maverick Pathfinder 2200V Center Console Fishing Boat with T/A Boat Trailer (A50324)
2003 Maverick...
John Deere HPX Gator (RUNS) (A50774)
John Deere HPX...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A51572)
2003 Isuzu NPR-HD...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
2018 Ford F-550 Truck Altec AT40G 40FT Insulated Bucket Truck (A50323)
2018 Ford F-550...
