Need this part
/ Need this part #1
Desert Bred
Goodyear AZ
1998 CKC TS 254 (Fei Dong 295T1)
#2. anybody know where i can get one or confirmation on a saturday?
/ Need this part #2
How about a description of what it is/does and/or a part number? Might help.
/ Need this part
hey guys. without the manual.. this is from the sump. it most likely is considered the main valve. it controls the fluid to the rockshaft / return flow from rockshaft. thanks for the info i've been in touch with chip. . just weekends you know so curious to get info on it.. appears talking to a friend that this
circled part is ok.. thanks again.. hey by the way i wonder if you guys have any experience and may be able to check out this video i want to make sure its ok function-wise before completing reassembly..
here:
http://www.tractorbynet.com/forums/hydraulics/291871-what-lifts-3pt-2.html
/ Need this part #5
I'm confused. The "rockshaft", in general parlance, is the shaft that the rocker arms ride on in the valve train assembly for the combustion chambers. Not sure what you are referring to in this case, can you be more specific? I can't understand what the relationship is between the combustion chambers and the lift box.
/ Need this part
someone had called this (#1) the rockshaft.. without a manual i see online that its called the rockshaft cylinder.
I was making the relationship between the rockshaft (cylinder) and the valve pictured below (#2) and how together they control the 3pt lift.
/ Need this part #7
Appears to be the valve assembly under the right floorboard (for lift and draft control). Don't know if the pieces can be purchase individually, or if it comes as an assembly. Chip will likely know.
//greg//
/ Need this part #9
A rockshaft is any shaft that doesn't turn 360 degrees. Like the big shaft that turns to lift the 3-pt arms.
2005 Ford F-150 Ext Cab Pickup Truck (A64556)
2005 Ford F-150...
2018 Chevrolet Tahoe SUV (A64557)
2018 Chevrolet...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
2009 BOBCAT T190 SKID STEER (A65053)
2009 BOBCAT T190...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
