Need stronger brakes, what can I do?
   / Need stronger brakes, what can I do? #51
   / Need stronger brakes, what can I do? #52
Anybody want to order a kit for a 10,000 pound axel and ship me the old drums? On a more serious note has anyone looked into building a set from vehicle parts? It wouldn’t cost nearly $2000 to buy 4 rotors and calipers for a truck.
   / Need stronger brakes, what can I do? #53
A good electric/hydraulic kit costs $800 on etrailer. Rotors and pads are cheaper than drum replacement.
   / Need stronger brakes, what can I do? #54
Having an accident because your 14k trailer that is hauling 10k worth of tractor while using cheap drum brakes is even more expensive.
I was not aware dexter axles had cheap brakes. :)
   / Need stronger brakes, what can I do? #55
I will reiterate that I have never used an electric over hydraulic before. But those who have say it is a huge improvement.
I plan on purchasing a 14k trailer (prob an EBY). I WILL have this set-up for it. With that much weight, I want it to be able to stop as quickly as possible.
   / Need stronger brakes, what can I do? #56
You still have to buy the pump and other accessories, pay tax and shipping, putting total cost upwards of $2000. Not knocking disk brakes at all. But, Dexter axles and drum brakes are very capable. If they are not doing the job, it is time to troubleshoot.
   / Need stronger brakes, what can I do? #57
It wasn't very long ago that drum brakes on all four corners of your car or pickup were good enough;
also most over the the road tractors did not have any front brakes and that was good enough.
Now most everything has disc brakes and the rotors keep getting bigger.
I know that I have no desire to go back to drum brakes on my vehicles,
so why are they good enough for a trailer.
With speeds and loads people seem to want to pull with a pickup and the tow ratings being waved about by the manufactures,
I would like to see the same improvements in trailer brakes, of course I always liked surge brakes.
   / Need stronger brakes, what can I do? #58
I agree.
I have a cheap time sensitive controller in my truck. I have to run it on 3 or less to keep from sliding the wheels on my empty dual wheel 10K Dexter axled 28+4 GN trailer that weighs 6,900 lbs.
   / Need stronger brakes, what can I do? #59
Drums are on almost all medium and heavy duty trucks. The few medium duty trucks with hydraulic disk did so to avoid CDL restrictions not because they’re better. My ton truck has rear drums and they work fine. It’s a massive drum not some crap you can hold in your hand. My previous 10 ton trailer with drums had fantastic brakes. It would lock down with my backhoe on it. I’ve never seen a road tractor without front brakes. What’s you definition of not long ago? Like 50s model stuff?
   / Need stronger brakes, what can I do? #60
70s. Not sure about 80s.
2019 FORD F550 XL SERVICE TRUCK (A51243)
2019 FORD F550 XL...
2012 Ram 1500 LARAM LONG (A50323)
2012 Ram 1500...
Loader with IH Brackets (A50515)
Loader with IH...
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
JOHN DEERE LOADER BRACKET (A51243)
JOHN DEERE LOADER...
1271 (A50490)
1271 (A50490)
