need specs for coil - tractor won't start
/ need specs for coil - tractor won't start #1
steveford14
West Grove, PA
Grasshopper 725 & Kubota B7100
I have a Grasshopper 725 with a Kubota 3 cyl 25 hp gas engine, which won't start. It turns over, but there is no spark. I 'd like to test coil, but don't know it's specs. Its marked 12581-68901.
Primary test result = 1.4 Ohms
Secondary test result = 11.66K Ohms
/ need specs for coil - tractor won't start #2
i don't have the specs for your coil but those are reasonable numbers for a standard automnotive coil. Primary could be a tad lower ohms but you are not open. Do you have battery voltage at the + term when in the run position? If you do, move the the ground side and see if it is being conrolled when cranking.
