Need some plow wisdom.
/ Need some plow wisdom. #2
In picture this appears to be a Category I plow, which would be compatible with your Branson 5220 tractor, which has a Category I Three Point Hitch. (Make sure it is not a Category II plow or it will not fit the Three Point Hitch on your Branson 5220.)
If it is a 12" plow your Branson with 55-hp and (tractor only) 4,123 pound weight and 4-WD will be able to pull it fine.
If it is a 14" plow your Branson may have to grunt a little but should still pull it satisfactorily.
(Measure from the center of one plow beam, to the center of the next beam.)
$275 is a very good price. Go for it.
PLOW ADJUSTMENT LINK: http://www.tractorbynet.com/forums/...oard-plow-wisdom-farmwithjunk.html?highlight=
Also have a 125 horse IH with cat 2/3 hitch. I know that one will pull it!
/ Need some plow wisdom. #4
You can PULL a Category I plow with a Category II/III tractor, but you cannot PLOW with a plow and tractor that are not matched. The tires on Cat II/III tractor will be too wide to roll in the bottom of a 12" or 14" plow's furrow. Tractor and plow have to be compatible. You cannot brute force a moldboard plow and turn sod successfully. See LINK, same issues:
LINK: http://www.tractorbynet.com/forums/attachments/348580-furrow-bending-top-link-please.html
Got it. Thanks.
/ Need some plow wisdom. #6
I had a similar three bottom. That is a good price, and looks in good shape. Don't see how you could go wrong.
Sent from my iPad using TractorByNet
/ Need some plow wisdom. #7
Only thing I see missing is coulters. If you are breaking out sod it's going to pull considerably harder and not do as pretty a job because of the lack of those coulters. They slice the sod just ahead of the moldboard for a clean cut.
Good price though.
2005 DRAGON 130 BBL STEEL VACUUM TRAILER (A65643)
2005 DRAGON 130...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
2022 EZ-GO ELITE...
48in Farm Jack (A65583)
48in Farm Jack...
3147 (A63117)
3147 (A63117)
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
