Need some painting advice
   / Need some painting advice #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
I have a Kaw Mule 2510 with cab that needs painted red for the fire dept...I found out we have some red paint on hand (older stuff has not been froze)
My question is is there any thing I need to do the the metal and plastic on the unit before I paint? I does not need to be a professional job but want to make sure it sticks well enough for a while. Oh it is army green right now.
   / Need some painting advice #2
DDT, I,m no painter, what I have done to prep materials to spray as you mentioned, I used 600 grit wet sandpaper and keep surface wet while sanding area.
This will give good adhesion for the new paint, HTH.
   / Need some painting advice #3
Red can be a difficult color to cover in one coat and get an even shade. You may want to prime gray first after sanding and cleaning. Don't know why, but gray seems to prep better for red.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
2022 JOHN DEERE 333G SKID STEER (A52705)
2022 JOHN DEERE...
2016 KENWORTH W900 T/A DAY CAB ROAD TRACTOR (A51406)
2016 KENWORTH W900...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2018 GENIE...
