Need some insight
/ Need some insight #1
Kacoos
Nacogdoches, Tx
Mahindra 7520
Hello, I was wondering if any one else has had the problem I have with my tractor. I bought new, a '14 Mahindra 7520 that 6 months old with 151hrs on the tractor. Yesterday while using the grapple, I lost at the exact time, loader and grapple controls, and all steering. The wheel just keeps turning and no wheel movement. After close inspection, I have found no leaks anywhere on the tractor and all fluid levels are correct. I was wondering if this might be an electrical issue so I checked all the fuses, and they are all good. Any thought, ideas would be greatly appreciated. Thank you!
/ Need some insight #2
Check hyd pump shaft coupler or it could be the shaft itself.
/ Need some insight #3
Remove pump output hose, place in a bucket and crank engine for a few secs, and see if you have flow.
You may have lost prime or the sump filter could be fouled if you have one.
Check suction hose at pump and see if the IN port is flooded.
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
2015 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 INTERNATIONAL...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
1999 Nabors Chip Trailer (A62613)
1999 Nabors Chip...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
2011 Chevrolet Silverado 1500 Work Truck (A62613)
2011 Chevrolet...
