need some info re. TL2100
   / need some info re. TL2100 #1
corelokt308win
1. Anybody know aprox how much hydraulic fluid it holds?
2. Where can I get a paper hydraulic filter, not impressed with the screen as it had dirt on both sides of the screen and the magnets were covered with about a quarter inch of metal dust.
3. Where I can get a new hydraulic outer filter cover?
4. How to tap into the hydraulics so that I can run the loader and a hydraulic winch on the back at the same time? The loader dosn't work when the winch is hooked up.
5. How much pressure does the hydraulics make?
   / need some info re. TL2100 #2
1. Buy a five gallon pail & fill to the full mark.
2.I can supply the OEM filter
3.I can also supply the OEM filter cover
4. Go to following for remote hook ups
hydraulic remotes
5.It should be around 2100psi.
How much is the new cover, and is the OEM filter you have paper?, and how much is it irregardless?
Thank you, Giles.
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
TMA (A49461)
TMA (A49461)
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
