Need some info on JD Cab Radio ideas....
   / Need some info on JD Cab Radio ideas....
I am buying the radio mount kit. I have bought some different speakers, and with some of the ideas that Nuru has given me, I am working on some additional speakers. I guess I am just a little excited to get it and get the radio in.:D
I was going to wait til august 1st to pick it up... but i just might go up this saturday if they get the loader in. I will not get to take care of the deal with the owner directly, but I think it will work out. If not, it will be next friday...
   / Need some info on JD Cab Radio ideas.... #32
I just finished installing the Auto cruise upgrade the sent me after they omitted it from the order. Found a coiple of extra connectors in the console, one is for the Beacon Switch, the other is for?
According to the manaul. TThese are the buttons that might be there...
Picture Note: All controls shown may not be installed on your machine.
A - Turn Signal Switch
B - LoadMatch Switch
C - Front Windshield Washer Switch
D - Display Mode Switch
E - Light Control Switch
F - Engine Speed Hand Throttle Lever
G - Park Brake Switch
H - Dual Selective Control Valve (SCV) Lever
I - Third SCV Lever
J - Rockshaft Adjustable Depth Stop Knob
K - Rockshaft Control Lever
L - Power-Take-Off (PTO) Selector Lever
M - Beacon Switch
N - Cruise Control Switch
O - Accel/Decel Switch
P - MotionMatch Switch
Q - Rear Work Lights
R - Rear Windshield Washer Switch
S - Rear/Mid PTO Engagement Knob
T - Diverter Switch
U - Front PTO Engagement Knob
V - SCV Lock Lever
W - Reverse Travel Pedal
X - Forward Travel Pedal
Y - Keyswitch
Z - Tilt Steering Control Lever
AA - Right Turn Brake Pedal
AB - Seat Belt
AC - Transmission Range Shift Lever
AD - Left Turn Brake Pedal
AE - Horn
AF - Mechanical Front Wheel Drive (MFWD) Lever
Nuru, do you have the electronic diverter switch? They also show a front PTO knob?
My bucket showed yesterday, but it will not get together until Monday.... Sucks....
   / Need some info on JD Cab Radio ideas.... #34
nmu98, actually, let me a bit more clear, underneath the console when you remove it, there are a couple of extra connectors. One is for the beacon switch, the other I don't know what that is for? There is a similar connector that sticks out beneath the seat. I will take pics of the one on the floor neatr tyhe east tomorrow, and post. I hope it is still there! LOL!
No diverter switch, or Front PTO.
I also plan to remove the shattered lower window and replace it, could not find the instructions so I am going to take a go at it as it does not look like it is too tough of a job to get done.
Sorry, I guess i went about answering your question from the top. I figured the only way to know what might lay benieth is to find out what Deere might have up top. So my guess was that some of the connectors might be for some of the factory switches you do not have?
   / Need some info on JD Cab Radio ideas.... #36
Oh, yes, I was looking at that too, but I ended up scratching my head I was thinking that maybe the extra connecto4rs were for the back-up alarm? But since I have a TM, maybe i should spen a little time and review it! LOL!
I think you are already on the right track....
BTW, I should be picking mine up at the end of the day Monday!:D
   / Need some info on JD Cab Radio ideas.... #38
congrats to you!
And we definitely want pics
   / Need some info on JD Cab Radio ideas.... #39
Did you get the factory harness? If so, that doesnt sound right...Mine plugged right in with no splicing of the factory harness at all (used the Adaptor Plug to adapt from Deere Harness to Kenwood) and everything works fine..its got power all the time, etc..
Hi Dave
Looking at doing the same thing with the radio in my cab. (used the Adaptor Plug to adapt from Deere Harness to Kenwood). Where did you get the adaptor plug? Was it included in the radio purchase or did it come with the JD factory wiring kit?
Thanks
Hi Dave
Thanks
You need to purchase it from a radio store. BUT, it is much easier to just cut the plug and connect it yourself. You would need to coonect the 2 plugs together anyway.
Then you can do some more custom ideas like mute on a switch or custom illumination.:D
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
14ft. Deer Gate (A55758)
14ft. Deer Gate...
VIN -1FDES6PM1HKAS3714 (A55788)
VIN...
