need some help with Michigan 55-3A Wheel loader
   / need some help with Michigan 55-3A Wheel loader #1
deiceman49
Campbell Hall, NY
Waldon 4100 Compact Wheel Loader; Michigan 55-3A Wheel Loader; 70 craftsman 18hp garden tractot; 06 cub cadet RZT50; 03 craftsman gt
Have issue with Brakes, pedals are frozen and can't press them down.
Also could really use a Wiring Diagram.
thanks for any suggestions and help.
dominik
   / need some help with Michigan 55-3A Wheel loader #2
Not familiar with this machine but on many pieces of older equipment the pedals are mounted on a shaft under the floor. You need to get it freed up. disconnect the rod from the bottom of the pedal to whatever it is connected to (master cyinder, axle, etc.) If the pedals are still frozen, start with your favorate penatrating oil. If that doesn't work you may need to put a little heat on the pedals. Before you are done you may need to unbolt the whole assembly and drive the shaft out of the pedals to get enough rust out and lube in to make the pedals move freely. Once you get the pedals moving you may find other spots in the linkage that are also frozen. Just start at the pedals and free thing up as you go. Good Luck.
Thanks I will try and start from there... any one else?
   / need some help with Michigan 55-3A Wheel loader #4
When was the last time the machine was operated?
this was operating last spring... the brakes were frozen since I got last November and before
yes was using very little without brakes... thats how I got it... it is on my small farm and not used outside.. I want to be able to clear snow and am not comfortable without the brakes...
and I think the brakes are combo air/hydraulic...
   / need some help with Michigan 55-3A Wheel loader #9
You could have an air over hydraulic system. Is your brake pedal a treadle valve?
   / need some help with Michigan 55-3A Wheel loader #10
First get the peddle free, then check the master cylinders for fluid.
Treddle valves get all boogered up from corrosion. Most likely you'll need to replace them. We replaced them on our Cat every few years when plowing snow.
2008 KUBOTA U45-3 EXCAVATOR (A51246)
2008 KUBOTA U45-3...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
John Deere GR72B 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
John Deere GR72B...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A53473)
2000 Kenworth W900...
2025 CFG Industrial MX15RX (A50123)
2025 CFG...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
