SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,633
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
I never had one spray that much water. Even if it did it would dry almost immediately. A patina of surface rust on the bare metal will wipe of with a scotchbrite hand pad. Even that is too much trouble for something that will make no detectable difference in the result of his refinishing project.ray66v said:It's important if your goal is get rid of rust.
You may not have seen metal rust from the moisture sprayed on by the sand blaster. But, I did this for a living, and I sure have.
A system like this, under the right conditions, can spray almost as much water as sand.
Yes, with the proper knowledge and products it can be treated. But, its not the best way to start out your new finish.
larry
