Need some help to identify tractor and some information on parts replacement. All help is much appreciated.
   / Need some help to identify tractor and some information on parts replacement. All help is much appreciated. #1
keikeyp
Ford
Please help me to identify the tractor and the hydraulic cylinder to the escavater that is needed.
   / Need some help to identify tractor and some information on parts replacement. All help is much appreciated. #2
   / Need some help to identify tractor and some information on parts replacement. All help is much appreciated. #3
Better pics would help
Do any serial numbers resemble this
   / Need some help to identify tractor and some information on parts replacement. All help is much appreciated. #5
Maybe take some new pictures?
   / Need some help to identify tractor and some information on parts replacement. All help is much appreciated. #6
Maybe just take the cylinder to a hydraulic shop. They will dig through a pile of zip lok bagged crap and get you fixed up. I take mine apart first. He matches parts. Charges me forty dollars. I put together. Now, if you go the parts route, you can buy them forty dollar parts for three hundred bucks.
   / Need some help to identify tractor and some information on parts replacement. All help is much appreciated. #7
It looks like a 3550 (does it have wet brakes? If so, the rear axle housing will look like a trumpet...small at the wheel, large at the center case.)
Look at the RH ledge of the clutch bell housing for model code, date code and serial number.
The backhoe has its own ID tag if it is still intact. It will have one of the following numbers:
19-388 for a 750/10' backhoe
19-389 for a 753/13' backhoe
19-390 for a 755/15' backhoe
This 19-*** number tells you what size/model backhoe you have to get the right parts.
BTW, welcome to TBN
2006 APPA TL (A55788)
John Deere 6120E (A50323)
John Deere 6120E...
***No pull string*** (A55851)
***No pull...
2013 MACK GU (GRANITE) TRI AXLE WINCH TRUCK (A55745)
2013 MACK GU...
Golf Cart (A55853)
Golf Cart (A55853)
