Need some help- small anti-freeze leak on Deere 2305
   / Need some help- small anti-freeze leak on Deere 2305 #21
Keep us posted Jason. I hope your end is better than mine. Keep after them and see if they will agree to fix it if the warranty expires before they find it. When they couldn't find my problem I just started to ignore it until it got bad enough to know it was the radiator. By then it was out of warranty. I ended up paying $350.
Al
   / Need some help- small anti-freeze leak on Deere 2305 #22
While they have your tractor tell them to check the seal where the pump mounts to the engine.
Do you ever smell coolant burning when you run the tractor? It's a very distinctive smell.
Hi
I will have to let them know to check the seal before I get it back. I can't smell anything abnormal that might be burning. I have never smelt burning anti-freeze but I could probably pick it out. I am not sure exactly where its leaking but hope they can trace it.
Take Care Jason B
Hi
Well the dealer phoned this morning, apparently the bottom of the Rad is cracked. They are going to be installing a new Rad on the tractor, should be a few days till I get the tractor back.
I was not the orginal owner of my 2305, so the warrenty has expired! Thanks for your help. If it still leaks after the new Rad is installed, I will check out the other suggestions.
Thanks Jason B
Gooseneck Trailer (A48081)
Gooseneck Trailer...
2013 HINO 338 (A48992)
John Deere 1450 5-Bottom Plow (A49251)
John Deere 1450...
2017 Ford F-250 Reading Service Truck (A48081)
2017 Ford F-250...
2006 Ford Econoline Van w/ Title (A49251)
2006 Ford...
Stainless Steel Sprayer (A49251)
Stainless Steel...
