Need some experienced electrical help with my S650G.......
   / Need some experienced electrical help with my S650G....... #11
If you aren't seeing some voltage at the dist side of the coil, ever, it likely means that there is a short to ground there. You might try disconnecting that wire from the coil, and then measure the resistance to ground from the end of that wire. It should change from almost nothing to infinite as the points go from closed to open (may give erratic readings due to the condenser in the circuit at first, but long term (a few secs) that what it should read in those positions). Note open/close the points with a stick of wood or some other insulator, by hand, for this test. If you don't have a helper, put a clean piece of paper/cardboard between the points to hold them open, so you can go read the electric meter.
I'd bet you are seeing close to 0 resistance all the time. That will give you no spark, and run current thru the coil continuously which heats it up. If this is the case, then either the points are not really opening, or they are plugged in wrong, or there is a short to ground somewhere in that wire.
If you do get the right resistance when you manually open/close the points, then try hooking it back up and see if you don't get a spark from the center of the coil when you manually open/close the points, you should.
If you do get a spark from this last test, then I'd check that the points are gapped correctly, and that the timing is set right. Might also be spark plug wires in the wrong dist cap holes, or play in the dist shaft too... Looking at the points as someone cranks the engine over, you should see the points open and close as the dist shaft goes around. If the points aren't opening and closing with each lobe of the cam that's the problem. If they are, then you should be getting a spark, although it may be at the wrong time.
   / Need some experienced electrical help with my S650G....... #12
Sorry dup post...
Well I tried unhooking the wire from the coil to the distributor at the distributor end and I show the same amount of voltage as at the coil and battery. I tried touching that wire to the wire inside of the distributor that goes to the points without any spark still. I will have to try checking the volts opened and closed as you mentioned when I can get an extra set of hands.
   / Need some experienced electrical help with my S650G....... #14
So, help me out here...
yoo were getting 0v when the negative wire was hooked to the coil, but unhooking it you got 12v??
If so, it could just mean the points are closed.
Take the distributor cap and rotor off to see the points. Now with the key on (no need to try to crank) hold the coil wire close to a good ground. Maybe 1/8-3/16 of an inch. Use a screwdriver and open the points. See if you have a spark jump from the coil wire to ground. No harm in trying several times, or opening and closing as fast as you can...
Finally got some time from work to give that a try. Still no spark.
Finally fixed the problem. Seems it was being grounded out going through the distributor housing. The rubber piece was bad and was letting it ground out before getting to the points. Fixed that and two fuses, now it has a nice pretty blue spark. Thanks again for all the help.
   / Need some experienced electrical help with my S650G....... #17
I too have had the same problem and changed all the parts listed including new spark plug wires. Need to know which are the 1-4 cylinders? I marked the originally but now second guessing
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
2019 CATERPILLAR 930M WHEEL LOADER (A51242)
2019 CATERPILLAR...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2016 CIMC 40FT CONTAINER CHASSIS (A52141)
2016 CIMC 40FT...
