Need some advice
/ Need some advice #1
Mike Madison
MF-35, Ferguson to-30, Kubota 245H, Kubota L3450, Kubota MX4700
Hello Good People. I'm considering buying an Oliver Super 55 tractor, diesel, for a very low price. The story is that the owner's friend borrowed it, used a lot of ether to attempt to start the engine, and 'blew a piston.' The tractor is good otherwise, straight tin, good tires, etc. Said to have all parts working as they should other than the engine.. I have not yet been to look at the tractor, but how should I go about evaluating the engine damage? It could have bent rods, bent crankshaft, all kinds of things. Or it could just be a damaged piston--fairly simple fix. Should I expect to take off the oil pan, if that's accessible? A total engine rebuild kit (sleeves, pistons, bearings, valves, etc) is perhaps $1500, so I could be going down an expensive rabbit hole. Any wisdom would be appreciated. Thanks.
/ Need some advice #2
Watching to see what the experts say.
My thought is diesels are usually over built, so I doubt crank damage.
/ Need some advice #3
Unless the "friend" attempted to start engine by towing with too much starting fluid sprayed in intake I doubt the crankshaft or conn. rods would be damaged. I think it would be a good idea to have rods/crank checked out by machine shop. More than likely top ring &/or ring land on pistons are broken. I think I've read the Super 55 has more collectible value than some other Oliver tractor models.
/ Need some advice #4
I will add that I have had three hydro locked engines one with water and the other two with oil/fuel rods were bent in two of them and the 3rd cleared the engine by pulling it down the road although I got soaked in fuel from the exhaust as we didn't realize why it wouldn't start.
two were diesels one a gasser - the diesels had the bent rods the gasser exhausted the fuel it could but the crankcase was till full but running luckily we shut it down after I got doused with gas and checked further
I doubt like the others here that the crank is damaged - you would be able to find used rods if you need those also
Bulldozer Rake (A64127)
Bulldozer Rake...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
16ft. Teak Wood Table (A61574)
16ft. Teak Wood...
2022 EZ-GO ELITE...
