Need solinoid refernce number for Jinma 204 3cylinder or starter number.
   / Need solinoid refernce number for Jinma 204 3cylinder or starter number. #1
meaford
Meaford Ontario Canada
Jinma 204
staticmap
   / Need solinoid refernce number for Jinma 204 3cylinder or starter number. #2
I had the started and solenoid rebuilt today. I installed but engine only turns two turns and stops turning. Battery checks o.k.Could their be a blockage in hydrolic line and pump is deadheading and prevents motor from fast turning?
   / Need solinoid refernce number for Jinma 204 3cylinder or starter number. #5
That's certainly a possibility. If you uncouple the QD's from the loader and hook them together at the hydraulic pump that will take all the components out of the system and allow the fluid to cycle through the pump without deadheading. Provided, of course, that the QD's themselves are sealing/coupling properly.
If it turns out that one of the QD's is not working right you can either by better aftermarket ones like Prince or you can simply remove the check balls from the existing ones. That would mean they no longer would shut off when uncoupled, but that's not really a problem since when you disconnect the loader you couple its hoses to themselves and likewise for the hydraulic pump hoses.
If you discover that on of the connections has come apart enough to let the check ball close, I'd strongly recommend replacing them all. In the meantime, you can re-couple them and use either stainless steel worm-drive hose clamps or even heavy duty zip ties to act as safety locks on the joints.
Let us know what you discover.
   / Need solinoid refernce number for Jinma 204 3cylinder or starter number. #6
Good Morning all, if you find out that you are having problems with your Quick Disconnects I recommend replacing them. We offer a Quick Disconnect by-pass kit. it allows you to remove the FEL with as much ease as you have with the quick Disconnects but you don't have to worry about the balls in there sticking. If those quick disconnects go out it can and probably will take out your Hydraulic Pump with it. Also for a Y380 engine I recommend a QDJ1332A gear Reduction starter. They are so much better, the Solenoids are internal which means no moisture can get in side and corrode the wiring. Also there is less drag on the glow plugs and better cold cranking. If you would like more info you can call me at 866-363-8193
Nan
Parts Dept
Keno Tractors
KARCHER PRESSURE WASHER (A51244)
KARCHER PRESSURE...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
NAMCO GRAIN-O-VATOR GRAIN WAGON (A51243)
NAMCO...
Road Brute Flat Deck Trailer (A50514)
Road Brute Flat...
2012 UTILITY VS2DX 53FT DRY VAN TRAILER (A52141)
2012 UTILITY VS2DX...
2000 BOMAG BW172D-2 SMOOTH DRUM ROLLER (A51242)
2000 BOMAG...
