Rims Need Rear Rims for Ford 2110.
   / Need Rear Rims for Ford 2110. #1
wclinton
Goshen Ct
Ford 2110
My moms tractor is a ford 2110. Rims are rotted from calcium leaking. Need two rims so get this tractor up and running so I can use for her property. Tires are F 151 A. Thats the best i can do on the id on tires. Any help necessary.
   / Need Rear Rims for Ford 2110. #2
Call Pine Plains Tractor & Equipment and ask for the parts department. We are an hour away and have a new aftermarket solution for 2110 rear rims for 13.6x28 ag tires. 518-398-7152. We are an hour from Goshen.
thanks will do.
   / Need Rear Rims for Ford 2110. #4
I have the same problem one of my rims are rotting from the calcium. Is the rim just the outer ring? Or a complete unit? If just the outer ring does it just bolt on or is there some type of modification that needs to be done, thanks Mark
   / Need Rear Rims for Ford 2110. #5
The rim bolts to the center disc. The aftermarket replacement rims I sell do require different hardware than the original, but the new hardware is inexpensive.
Heres another question. What is the best way to pull the calcium out of tires and gather it into a vessel.
   / Need Rear Rims for Ford 2110. #7
Most people hire a tire service to pump the fluid and change the tires. There are alternative methods using sprayer pumps, or air pressure, and gravity. If you place any value on your time, both in doing the job and getting set up for a once in a decade task, most make a phone call and write a check.
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
Ran during check in. No longer running. (A51694)
Ran during check...
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
2002 Sterling M7500 Acterra Lift-All LA04C51 51ft Insulated Forestry Chipper Bucket Truck (A50323)
2002 Sterling...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50323)
2016 Big Tex 14ft...
