need rear brakes on mf 65
   / need rear brakes on mf 65 #1
mike cook
tennessee
65 massey
Hello onmy 65 I need to redo the brakes plan on putting all new parts and seals how big of a job is it to do ???
   / need rear brakes on mf 65 #2
Its not to big of a job as long as you have some mechanical ability and a service manual to guide you through.
   / need rear brakes on mf 65 #3
To me the biggest issue was handling the loaded rear tire on our MF 135. I needed a second person for that part of the job. The rest was like doing drum brakes on a truck or car. I am guessing the MF 65 isn't a lot different.
   / need rear brakes on mf 65 #4
I did mine last year if you have an engine lift it is not to bad a job the brakes are inside the axle housing you have to split it of the differential housing when you get it removed you will see a plate that has to machine screws holding it on remove them and you can get at the brakes when I did mine I replace the seals and some bearings that were pitted. The engine lift makes it much easier as the castings are very heavy if you don't have one I would rent one
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2017 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 GMC Sierra...
43017 (A51691)
43017 (A51691)
3pt 6 Row Rolling Cultivator (A50121)
3pt 6 Row Rolling...
