need rear brakes on mf 65
   / need rear brakes on mf 65 #1
mike cook
tennessee
65 massey
Hello onmy 65 I need to redo the brakes plan on putting all new parts and seals how big of a job is it to do ???
   / need rear brakes on mf 65 #2
Its not to big of a job as long as you have some mechanical ability and a service manual to guide you through.
   / need rear brakes on mf 65 #3
To me the biggest issue was handling the loaded rear tire on our MF 135. I needed a second person for that part of the job. The rest was like doing drum brakes on a truck or car. I am guessing the MF 65 isn't a lot different.
   / need rear brakes on mf 65 #4
I did mine last year if you have an engine lift it is not to bad a job the brakes are inside the axle housing you have to split it of the differential housing when you get it removed you will see a plate that has to machine screws holding it on remove them and you can get at the brakes when I did mine I replace the seals and some bearings that were pitted. The engine lift makes it much easier as the castings are very heavy if you don't have one I would rent one
2004 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2004 STERLING...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
2008 UTILITY REEFER TRAILER (A51222)
2008 UTILITY...
2016 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A51219)
2016 INTERNATIONAL...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
Toro Workman Cart (A50322)
Toro Workman Cart...
