Need Ratchet Chain Binder Source....
/ Need Ratchet Chain Binder Source.... #1
Utopia Texas
Platinum Member
Brookshire & Cat Spring,Texas
Kubota B2650 / Kubota L6060 / Kubota ZD2300
I've looked at all the ratchet chain binders on Northern Tool, Harbor Freight, Amazon and Ebay and wonder how reliable these may be considering most are probably made in China. It do not mind paying more money for a guaranteed quality product that I can assume is safer. Any ideas where to look on the Internet? Thanks...
/ Need Ratchet Chain Binder Source.... #2
I have a set of 4 ratchet binders. 2 from HF and 2 from TSC. They are all made in China. That being said, I have used them for over 10 years now without problem. Just have to keep the threads greased and the ratchet mechanism lubed. You'd have to do that no matter who makes them. I think AW Direct sells USA made ones.
/ Need Ratchet Chain Binder Source.... #3
I buy mine from my NH or local Kubota dealer. Both carry the same binders and they go on sale from time to time. I don't use grease, but do use silicone spray lube to keep things working nicely.
/ Need Ratchet Chain Binder Source.... #4
Ratchet binder is pretty much just a lever, wedge and a screw. 3 of the simple machines, kind of hard to mess that up.
/ Need Ratchet Chain Binder Source.... #5
I have the HF 3/8" ratchet binders and they work well. I have racked them down tight enough to squat my 8500 pound tractor and never any problem. The chain links on them are at least 5/8" diameter and rated at 5200 Lbs. (same as a 3/8" Gr 70 chain) I wouldn't hesitate to use them on anything my 12K rated trailer will haul. I do remember that the ratchet binders are higher rated capacity than the breakover type also.
/ Need Ratchet Chain Binder Source.... #7
/ Need Ratchet Chain Binder Source.... #9
I bought two of these binders a few years ago. http://www.thecrosbygroup.com/html/en-US/pdf/pgs/252.pdf They're made in Longview, Texas. I pass their plant frequently. I have several Lebus breakover binders that are probably over 40 years old and show no sign of wear. You can buy these online but you can probably find them at a truck rigging dealer. I bought mine a Dealers Truck Equipment. These binders aren't cheap, you'll pay over $125 each for them.
/ Need Ratchet Chain Binder Source.... #10
Harbor Freight for me. That is the kind of stuff that they do well. Floor jacks,chains,binders and drill presses. Probably about 1/2 price of most places.
2026 Loadtrail 20ft. 7 Ton T/A Deck Over Flatbed Equipment Trailer (A64194)
2026 Loadtrail...
46181SFL (A64557)
46181SFL (A64557)
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
10000LBS Two Post Auto Lift (A64194)
10000LBS Two Post...
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
