Need quick disconnects compatable with the Stucci's
   / Need quick disconnects compatable with the Stucci's #1
Clumber
Northern Virginia
Kubota B2601 HST Nov 2019
I am building extension hoses for some of my attachments for my PT-425. I will explain more in another thread. The stock quick disconnects are Stucci (Italian) -- have not been able to find on-line. Does anyone have a compatibility chart listing other brand models that can connect to the Stucci's? Prefer to purchase from Surplus Center or Discount Hydraulic Hose. Need equivalents to:
1/2" Female STUCCI BIR12 B07 NP
1/2" Male STUCCI BIR12 A07 NP
1/4" Female STUCCI IR14V L06 NPT
1/4" Male STUCCI IR14V ?06 NPT
The stock hoses are:
Parker Tough Cover 451TC-8 3000 PSI
Parker Tough Cover 451TC-4 3000 PSI
Here are the hoses I am buying from Surplus Center:
Surplus Center - 1/2" X 60" 1/2 NPTM X 1/2 NPTM 3000 PSI HYD HOSE
Surplus Center - 1/4" X 60" 1/4 NPTM X 1/4 NPTM 2750 PSI HYD HOSE
Note that the 1/4" hose is only rated for 2750 PSI. Is this close enough to 3000?
   / Need quick disconnects compatable with the Stucci's #3
Supposedly the BIR series is ISO A compatible, so ISO A connectors from any manufacturer should work.
The IRV series is ISO 5675/ Agriculture, so again just need to get connectors compatible with this spec.
Thanks for the help folks.
   / Need quick disconnects compatable with the Stucci's #5
You could try Bailey.
1-800-800-1820
That's where I got some for my 2001 model PT425 for the main PTO. Don't remember the brand name, but it was Italian.
Give them a call. They were very helpful a few years ago.
Bailey Hydraulic Cylinders Manufacturer
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
Greenworks Commercial 82V CZ60R Zero-Turn Mower-DEMO UNIT (A56438)
Greenworks...
2016 Chevy Silverado Z71 4wd 5.3L V8 (A56438)
2016 Chevy...
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
