Need Problem Diagnosed
   / Need Problem Diagnosed #1
bulldog7
Wilsonville, Al
Yanmar 1610D
The last few times I have used my tractor, 1610D, it would have spells that
it didn't want to rev up when I gave it fuel. If I had the idle set on 1000 rpm for example and kick the clutch in it would fall well below that idle and when I open the throttle the engine takes a second or two to turn back up and then shortly after it seems to run just fine. I am not getting any smoke from it. Has anyone had this problem or might have an idea what the problem could be? It does not do it everytime I use it.
Thanks for your help. This is a great forum.
   / Need Problem Diagnosed #2
Have you checked/replaced all of your filters lately? Does it ever seem like it wants to run too fast or just always too slow?
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
Thanks for your reply Aaron. I have just changed the fuel filter and recently the air filter as well. The engine never wants to run too fast, just slowing down and acting like it does not want to take the fuel. Do you think it could be condensation in the fuel tank. I have drained some fuel out but didn't see any water.
   / Need Problem Diagnosed #4
It is hard to diagnose intermittent problems like that. I would just be sure that you have a steady stream of fuel going into the injection pump. Other than that, if it does not do it very often, you may need to just wait & see if it gets worse so you can locate the problem.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2018 FREIGHTLINER...
KUBOTA B7510 TRACTOR (A51247)
KUBOTA B7510...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
UNUSED AGT MX MRT14 STAND ON SKID STEER (A51247)
UNUSED AGT MX...
CASE IH 2555 4R COTTON PICKER (A51247)
CASE IH 2555 4R...
