Need perfect bucket for a toothbar?
/ Need perfect bucket for a toothbar? #1
MA1920
Central MA
Ford 1920
I recently started to look at toothbars but am concerned that the bucket may have too much wear on the cutting edge to successfully bolt on a toothbar. Does the edge have to be "factory new" for the bar to fit properly?
I measured from the inside of the bucket to the cutting edge at both ends and the center, and came up with:
one end: 18 3/8"
other end: 18 1/2"
center: 18 5/8"
Also, the cutting edge on the outside of the bucket extends beyond the part the runs the bucket width 1/4" on one side and 3/8" on the other. I hope that's clear.
If the cutting edge is too worn, can I take an angle grinder to it? Is it possible to replace the original weld on cutting edge with either another welded one or bolt on, before the toothbar is installed?
All comments appreciated.
Bob
/ Need perfect bucket for a toothbar? #2
Bob,
I would not worry too much about it. It sounds like you will not have a problem. If you do, a little heat (AKA Torch) and a little persuasion (AKA a BIG Hammer) will get you going. Really your cutting edge is not that far out.
Gary
/ Need perfect bucket for a toothbar? #3
I added a toothbar (self fabricated) to my 4' bucket that is about 10 yrs old.
Needless to say there was considerable wear and some distortion.
The bottom cutting edge, based by comparison to the side cutters, probably had anywhere from 3/8-1/2" wear.
I did have to use some persuasion (sledge) to get a fit due to the distortion.
Once installed with the side bolt holes drilled nothing matters anymore.
Just maked the bucket lip all the stronger.
COLE 4R TWIN ROW PLANTER, 3PT (A64280)
COLE 4R TWIN ROW...
2015 Jeep Patriot Sport SUV (A61574)
2015 Jeep Patriot...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
BALDER INDUSTRIAL 20 HP MOTOR (A64281)
BALDER INDUSTRIAL...
UNUSED RANCH HAND BRUSH GUARD (A64280)
UNUSED RANCH HAND...
Caterpillar E120B Excavator Service and Parts Manuals (A63117)
Caterpillar E120B...
