Need Part for Hinomoto E260
   / Need Part for Hinomoto E260 #1
Travis_R
Veteran Member
Livingston Parish, LA
Yanmar YM2500
Looking for a water pump for a Hinomoto E260 tractor. Would also like any and all information about this Hinomoto model. Can't find anything on it...
Is there an equivalent Massey model to this one?
The water pump is the only thing stopping this tractor from running the way it should.
Tractor isn't mine, it belongs to a neighbor.
Is there anybody on here who can point me in the right direction??
THANK YOU.
   / Need Part for Hinomoto E260 #2
I don't know if this is right but after looking online it appears that the E26X models might simply be the 2 wheel drive versions of the 260x models. I can't confirm this. Seems like the few pics of E260,262,280 models I found are 2WD though...is your neighbors 2WD by chance? This is pure theory on my part but maybe a 2602 or 2604 pump will fit it? Tractor data lists the 260X models as having a Toyosha 84.82 ci/1.4L engine...what's the neighbor have?
   / Need Part for Hinomoto E260 #3
If nothing turns up - I thought there were water pump repair shops who could fix anything, probably for a price. Bearings, seals, and hopefully the impeller should be generic or easy to duplicate for the specialists who have access to parts catalogs.
Maybe ask the local NAPA store who supplies their rebuilt water pumps??
I haven't looked for any engine numbers yet, but it's for sure a 2 wheel drive tractor. I'm gonna try and get the engine numbers tomorrow and I might even try to take a few pictures and post them on here...
Thanks for the replies.
Ok found the whole problem...
It's not a Hinomoto E260. I'm not even sure if there's a E260 out there! He told me completely wrong.
Anyway, he has a 2 wheel drive Hinomoto E230 tractor. He ordered the water pump from "Southern Global" in, I believe he said, Hattiesburg Mississippi. Should be in either tomorrow or the next day.
THANKS FOR THE REPLIES.
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
1985 International X Con Semi (A50514)
1985 International...
7ft Double Leg Lifting 5/16 G80 Chain Slings (A49462)
7ft Double Leg...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
2003 DITCH WITCH 3700 RIDE ON TRENCHER (A51242)
2003 DITCH WITCH...
