Price Check Need Opinions on a B3030 Price, Please?
   / Need Opinions on a B3030 Price, Please? #1
My Hoe
Platinum Member
NYS--Various Parts
Kubota B3000HSDCC, BH77, 5' Belly Mower, 6' Hyd. Angle Plow
Hey all,
I am interested in a B3030HSDCC, and found one at a dealer. It was put in service in 2010. They are asking like $23,000., with the following equipment:
Front snow blower, with Hydraulic Chute Rotation
Subframe, etc, for the blower, obviously.
Rear defogger which, in this case, means it is a true "Cold Cab" (I had them confirm that for me, to my satisfaction). I believe this also means the tractor comes with a heavier-capacity alternator, but the exact amperage figure escapes me, at the moment.
It has rear work lights (as well as front ones).
The deluxe TPH that comes with all B3030's.
It has something like 25 hours on it, but I did not get the backstory as to why the original owner traded it.
It looks to be in like-new condition.
That's the good news.
The bad new$ i$, I would be adding:
1. an FEL
2. an SSQA-capable, hydraulic grapple, of some type, for the FEL, in a 48" width. The dealer recommends a Bradco model, which I believe is owned by Paladin?
3. an SSQA-capable, non-Kubota dirt bucket,
in a 54" width, probably by the same company I get the grapple from. The non-Kubota bucket thing is to avoid the cutting and fabbing costs (not to mention hassles) of doing surgery on the standard, Kubota bucket, to accept the SSQA female plate. I weld, but I'm no fabricator, so I would have to hire it done. I like the idea of an SSQA bucket, and no fabbing required.
a) I do want the dirt bucket to be able to accept W.R. Long's Flat Toothbar, which allows backdragging without the dentition marks, leaving a smooth surface.
4. A Woods BH80-X "Groundbreaker" (curved boom) 8' backhoe, with adjustable swing speed, and the optional, rubber-backed pavement, outrigger pads.
5. A hydraulic thumb for the Woods hoe,
to work with Woodsエs 16 bucket.
6. A 3" rear-wheel spacer kit.
7. Fender Extensions which I believe are simply rubber skirts, bolted (or riveted?) onto the rear fenders. Are these to help keep road salt, mud, etc? off of the cab sides, especially when running the 3 wheel extensions? The Kubota website has a price of $106. for the fender extensions, I believe. Obviously, I would have to add labor to that.
This dealer is either very busy, or otherwise seemingly-reluctant to give me prices on the additional equipment I hope to bundle into this purchase (or both), other than telling me the Paladin Grapple (actually a Bradco, I later learned) would be $1,895. When I asked if that included labor (to power the grapple) I was told "I don't know...." Yet at the same time, they're pressuring me to make a decision--a decision on exactly what, I do not know, as I cannot decide to buy something I've not been given all the pricing information on yet.
So I figure I'd better get the ball rolling, and at least see what the assembled Brain Trust here thinks about the price of the tractor and snow blower, by themselves, for like $23,000.
I will add that the fact that this machine is a true "Cold Cab" model makes all the difference for me, as I want to be able to see out the back window, while snowplowing, and the factory, in-glass defogger (wires) do just that (in theory). Of course, being a cabbed B3030, it has heat, A/C and the stereo I won't be able to listen to, as I'll be wearing Peltor 30dba-reduction earmuffs, I'm sure, due to the HST whine. I've read that cabbed tractors tend to be louder, in this regard, than uncabbed models, and I wear the 'muffs when running most any power equipment, anyway.
To the asking price, I will have to add shipping. The two quotes I've received so far are about $1,700., so I've got to figure that in, as well, because there are NO such tractors like this in my area, so I've got to "pay the freight," literally. LOL
Other than regarding the Paladin (Bradco) grapple, I have received zero pricing information on my proposed attachments, so I'm not expecting opinions on that, but I am CERTAINLY open to suggestions re: my anticipated implements/options, etc?
Oh! Intended Uses:
I. Snow Blowing
Obviously, snow blowing is in the plans, as this will be going to the upstate New York area.
II. Gardening
We currently have about 1.8 acres, and hope to buy two more, but the additional acreage is primarily a buffer against future neighbors, as it is, by turns, either too hilly or wet, to do much with. The original 1.8 acres are largely flat, however, and we plan to have vegetable gardens, so I was hoping to be able to pull a one bottom (or possibly two-bottom?) plow with the B3030. I also wouldn't mind simply (back)hoeing a garden, instead of buying a rototiller, so the hoe is partially justified by that "rototilling and de-bouldering" of the topsoil, the latter via the thumb.
III. Firewood Processing
On another post (LINK: Best Bucket or Bucket/Grapple Combo for Picking Up Firewood Splits, at http://www.tractorbynet.com/forums/kubota-owning-operating/252279-best-bucket-bucket-grapple-combo.html) I am attempting to solicit information on which grapple is best at moving firewood splits. I anticipate using the front grapple to grab bucket-sized loads of splits and move them from the wood processing area to a special "Firewood Porch," to minimize the physical labor, as I've had back surgery.
IV. Used Parts Inventory Handling
The backhoe will, first and foremost, hopefully be used as a "crane," as I plan on using it to move inventory in a small business I have planned out. The barn on the property is fairly unusable, due to some built-in, structural "quadrants" inside it, that cannot be removed. The hoe will enable me to lift my inventory OVER these low-walled "quadrants," and thereby using the space within them.
Questions I Have:
1. How is the $23,000. Price?
Is $23,000. a good price for a true Cold Cab, 2010 B3030, with just the front-mounted snow blower (with hydraulic chute rotation)? Again, the machine is a 2010 with about 25 hours on it. (The dealer says that because of the snow blower being present, I will not have to buy the $899. four-way valve to run an FEL, because this machine already has it, as it was required to operate the snow blower with).
He did say I would need rear remotes to operate the thumb on the backhoe, of course. He told me the rear remotes were like $400-500., but he couldn't tell me whether this included any required labor or not. :confused:
The backhoe will be powered by tractor-hydraulics, as opposed to a PTO-driven pump.
I'm hoping to run the front grapple off of the rear remotes, and thereby avoid buying additional (front) remotes.
2. Difficulty of Snow Blower Removal/Installation?
Please see "Firewood Processing" Processing, above. I anticipate having the FEL with grapple on, most of the time (processing firewood in summer, moving it in winter) but I just realized I will have to remove not only the front-mounted snow blower, but also probably the snow blower's subframe, in order to mount the FEL and move my firewood.
Is that correct?
How much physical labor and time are involved in uninstalling and reinstalling the snow blower and subframe? (My back surgeon is great with a knife, but he tells me I must adhere to a ridiculously-low weight-lift limit, FOR LIFE, so I wanted to know what the heaviest piece I'd have to "hoss," would weigh, approximately, during the removal/installation of the snow blower and it's subframe?).
Or can the blower subframe stay on, while I have the FEL on?
Thanks, in advance, for any and all feedback, on the questions I've asked, or questions I should have asked. In other words, all comments and criticisms are welcome!
Sincerely,
My Hoe
   / Need Opinions on a B3030 Price, Please? #2
If it's any help, I paid $24,800 (before NYS sales tax) in Feb. 2009 for a brand new B3030 HSDCC with LA403 loader. I know that front mount blowers are an expensive option. My tractor had one as it sat on the lot, but I had them remove it and put the loader on, as I already had a rear mount blower.The breakdown was $20,100 for tractor and $4700 for loader.
So $23k is probably in the range for a 2 year old machine with so little on the hour meter and the front mount snow blower.
   / Need Opinions on a B3030 Price, Please? #3
Well, I typed a long-winded response, but it appears to have gotten lost in cyber space. Unfortunately, I'm not interested in doing it again.
The condensed version is.......
IMO opinion, the price is a couple grand high. The 60 amp alternator and rear defogger are nice, but you are out of your friggin mind to pay 1700 in shipping on a B3030. Why not just add the options to an HSDC ?????????????? Perhaps you could have your wife bop you on the head with a tire iron to bring you back to reality ??
No rear remote is needed for the factory installed thumb on the 80X.
Thumbs up on the wheel spacers.
I do not believe you can run the blower sub-frame with the loader on, but I've never actually tried it. With the loader off, installing the blower takes me about 15 minutes?
Anything Bradco is high quality.
   / Need Opinions on a B3030 Price, Please? #4
Sounds high to me for just a snow blower with no loader. I would go to Kubota build my machine and load it up with everything you want, then take 12% off list and another 12% for used and see where you are. I think you will be pretty close to your used price and you can get a warranty and 0% financing right now.
   / Need Opinions on a B3030 Price, Please? #6
I looked up my purchase of a B3030 without the cab.
The B3030 with R4s was 18,013.00 retail and I paid 14,410.40
The LA403 was 2,780.00 retail and I paid 2,502.00
The 60" bucket retailed for 559.00 and I paid 503.10
The numbers are showing that I got 20% off the tractor and 10% off the attachments. This was is July of 2010. At that time and if my memory is correct, the cab added 5,000 to the tractor price. This would work out to a purchase price of about 18,400 for the cabbed version new in July of 2010. I hope this information is useful to you.
2025 Wolverine PRP-12-72W Ripper Attachment (A50860)
2025 Wolverine...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A48081)
2022 Chevrolet...
2005 Ford E350 XLT SD Passenger Van (A50860)
2005 Ford E350 XLT...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A50397)
NEW 2022 Load...
2019 Skyjack SJ1256THS 12,000LB 4x4 Rough Terrain Telehandler (A49346)
2019 Skyjack...
(3) VACUUM PUMP TANKS (A50854)
(3) VACUUM PUMP...
