need new trailer brakes...thoughts?
   / need new trailer brakes...thoughts? #1
v8only
Mb
1988 John Deere 755
Hey all,
I just bought a used trailer that needs all 4 brakes redone, also the drum/hub assembly is very old and has not been cleaned for a long time, i will be getting the drums re ground to clean them up and put in new studs and bearings.
I am thinking of picking up these:
New 12" x 2" Electric Trailer Brake Assembly Left Right for 7000 lbs Axle | eBay
or
Electric Trailer Brakes Dexter 12" x 2" Electric Trailer Set of 4 | eBay
anyone think that one is better than the other? are they all the same or do you suggest i look for something else?
I dont really need both axles for braking, should i just convert 2 to disks and buy a converter?
   / need new trailer brakes...thoughts? #2
Hey all,
or
I like Dexter, and am a fan of brakes in all positions.
Not sure about that particular size, but I've seen data on Dexter's auto-adjust trailer brakes. Don't know the price adder, but seems like a good idea for a trailer you plan to have for a while - many folks don't adjust their brakes often enough, or maybe not at all.
Rgds, D.
   / need new trailer brakes...thoughts? #3
I had a trailer with one set of axles with brakes. Second axle with no brakes. Bent the no brakes axle. Replaced it with a new axle with brakes. Trailer now has enough braking power to stop itself with a load. Much safer to use.
I kind of prefer buying American made stuff when possible. It looks like the Dexter brakes have a bigger magnet which may be a bonus.
   / need new trailer brakes...thoughts? #4
You don't say what weight that trailer is going to be when loaded. And I don't know anything about either of those eBay sellers, but . . . (1) I'd definitely want brakes on both axles, and (2) that's the brand, size, etc. that I'd probably want.
   / need new trailer brakes...thoughts? #6
I purchased a complete set of self-adjusting brakes (from the backing plate out) for my 14k trailer from etrailer.com. I have no complaints.
its 10,000 lbs trailer, the current drums/hubs that are on it now are 12"x2" so i was going to re use my drums and just get new guts. When loaded it to the max it will have a vehicle on it and be pulled with a GMC 1500.
   / need new trailer brakes...thoughts? #8
I am a fan of disc brakes. I have converted 2 of my 3 trailers. Worth every penny.
Chris
   / need new trailer brakes...thoughts? #10
I've not had a trailer with disc brakes, but naturally prefer the disc on cars and trucks. But when I had a fifth-wheel RV with 3,500# axles and 10" brakes, the brakes were not bad but were not going to lock up the wheels when I was running 7,300# on the axles and 2,500# on the pin. Anyway, I went to the Dexter factory in Indiana in 1990 and had 5,200# axles with their 6,000# tubes and 12" brakes custom made for my trailer, then I had to back way off on my controller because that would lock up the wheels easily. So I think the OP will be happy with those brakes, although it might well be even better with disc brakes.
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2011 Mercedes Benz Sedan (A51694)
2011 Mercedes Benz...
2025 CFG Industrial MX20R (A50123)
2025 CFG...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
Tailgate For Pickup Truck (A53117)
Tailgate For...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
