Need more down pressure on my 3PL for a Ripper
   / Need more down pressure on my 3PL for a Ripper
I start about 2 - 3 feet before the stump and work around it.
   / Need more down pressure on my 3PL for a Ripper #12
Try moving the top link to the bottom hole like jeff9366 mentioned:
I moved the top link as Jeff suggested but it made no difference. Had a pause while I fitted a Quick Hitch system. It gives me another 4" length on the lift arms. It also put more angle on the tooth.
I strapped a bag of cement onto the top of the ripper and it made a big difference. It could use a little more weight but it is working a lot better. I managed to get it deep enough to rip some large roots around a stump that I hadn't been able to shift and once I pulled them up the stump gave in and toppled. Thanks for the suggestions. Problem solved.
   / Need more down pressure on my 3PL for a Ripper #15
Have you checked the tip angle when it’s fully down?
As per the second post!
   / Need more down pressure on my 3PL for a Ripper #16
As far as which hole to use for the top link on your tractor there are a couple of variables.
Read your manual for some idea of which to use.
Also "if" your tractor is equipped with draft control your manual will provide the information if one position is more sensitive for the draft control then the other. Most of the smaller draft control equipped tractors sense the pull on the top link bracket.
In the case of the ripper it may be flattening the shoe out at it's designed depth,
one way to check that is to back over a ditch or hole and lower the ripper down to the desired depth and view the angle of attack at that level.
It has a good angle when lowered right down. It is working well with the weight. Just need to add some barbell weights LOL
   / Need more down pressure on my 3PL for a Ripper #18
That would be easy to do, drill your upright for the bar:
Exactly! I often see stuff like that sitting on sidewalks that folks are trying to get rid of so I will grab some one day. 30 - 40 kg would be just right. I only have 20 kg at the moment but it is working.
2008 INTERNATIONAL DURASTAR 4300M7 SBA 4X2 DUMP TR (A51243)
2008 INTERNATIONAL...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
International 475 14 ft Disc Harrow (A52128)
International 475...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
John Deere 12' Grain Drill (A50515)
John Deere 12'...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
