need large culvert in central ohio
   / need large culvert in central ohio #71
Mike, sounds like you are getting a lot of helpful information locally. I have seen the gabions in use, though I didn’t know the name. When I lived in Atlanta there are a few streams that are notorious for over flowing when ever we had big rains. Of course they are in the exact area that people build million plus dollar houses for some reason. Several of these streams had been lined with gabions stacked like retaining walls to prevent erosion. As I recall the wire was more like cyclone fence material. Hog wire might be strong enough but would it hold up to constant contact with water? I don’t see any reason that the wire cages could not be filled with broken up concrete if you have a good source. If your source is large enough and the concrete is broken small enough it would make a good road base also.
MarkV
I figure it is about time for an update. Idid finaly order a culvert from contech. It is a 10 gauge 9ft 6inch round culvert
that is pushed down to roughly a D shape making the area at the bottom larger. the cost was 3725.60 plus tax delivery included. 3967.76 with tax. I am expecting delivery around the end of the month. I am happy that I am gettin g it and getting it installed soon pics will follow delivery and install. It will weigh 3984 lbs so about 1 dollar a pound.
Mike
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
2014 INTERNATIONAL PRO STAR (A50854)
2014 INTERNATIONAL...
2005 Ford F650 Fire Truck (A49461)
2005 Ford F650...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
2012 John Deere 7230R (A51039)
2012 John Deere...
