Need JRW Snowblower Impeller blade
   / Need JRW Snowblower Impeller blade #1
Blowingsnow
John Deere 5320
Hello,
I need to replace impeller blade for 2004, Model S70 JRW blower, 26" fan, four blades. Welder says he can fix but might take 6 or more hours, It's pretty beat up from years of blowing rocky roads! I understand JRW is no longer in business? Might just have the welder go to it, but thought I'd ask around. Thank you!
   / Need JRW Snowblower Impeller blade #2
You might take some measurements then measure other blower brands to see if one of them will interchange with yours.
   / Need JRW Snowblower Impeller blade #3
What is the depth of the drum and the gearbox shaft size? 26 inches is a very common snowblower fan size but the depths do vary.
A few years ago we had to check about getting a 26 X 10 fan made and the quote was $6-700 Canadian.
I'll do that, thanks!
I'll have to measure and see, thank you!
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
Champion C80 B Motor Grader (A50322)
Champion C80 B...
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
Vermeer 630A Stump Grinder (A50515)
Vermeer 630A Stump...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
Coyote Steel Target (A50515)
Coyote Steel...
