Need JRW Snowblower Impeller blade
   / Need JRW Snowblower Impeller blade #1
Blowingsnow
John Deere 5320
Hello,
I need to replace impeller blade for 2004, Model S70 JRW blower, 26" fan, four blades. Welder says he can fix but might take 6 or more hours, It's pretty beat up from years of blowing rocky roads! I understand JRW is no longer in business? Might just have the welder go to it, but thought I'd ask around. Thank you!
   / Need JRW Snowblower Impeller blade #2
You might take some measurements then measure other blower brands to see if one of them will interchange with yours.
   / Need JRW Snowblower Impeller blade #3
What is the depth of the drum and the gearbox shaft size? 26 inches is a very common snowblower fan size but the depths do vary.
A few years ago we had to check about getting a 26 X 10 fan made and the quote was $6-700 Canadian.
I'll do that, thanks!
I'll have to measure and see, thank you!
2011 Mack CHU613 T/A Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
John Deere 8430 Track Tractor (A50514)
John Deere 8430...
Fire Truck (A51692)
Fire Truck (A51692)
2013 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2013 Ford F-450...
IH 470 Disk (A50515)
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
