Need INJECTION PUMP ASSEMBLY KIOTI CK30
/ Need INJECTION PUMP ASSEMBLY KIOTI CK30 #1
srusse
Central Louisiana
Kioti Ck30HST FEL, Mechron 2200, Grasshopper 325A ZTR
My dealer is going out of business and the mechanic (friend) sez my Injection Pump has failed on my 2007 CK30HST w/1500 hrs of quality service. Is there any dealers out there that has a New E5800-51016 InjectionPump Assembly for sale? Could you please call me at 318-640+8619 or 318-229-1470 (c) and lets talk. BTW the dealership is/was South Circle Tractor, Alexandria, LA and we need a new biz to step forward and take up the dealership. This has left a bunch of us without mx service.
/ Need INJECTION PUMP ASSEMBLY KIOTI CK30 #2
There is an injection pump guy on here, send him a pm, he might be able to rebuild yours for you
the user name is thepumpguysc
/ Need INJECTION PUMP ASSEMBLY KIOTI CK30 #3
Enjoyed our conversation on the phone. I posted a post about cold weather and junk fuel in the owning and operating section. Might be worth reading, cause it tells of my trouble with cold weather and diesel fuel. Others put some pretty good reply posts also. I notice you are a retired pilot. If you by chance have access to some jp5, a little jet fuel mixed in will also work well to keep you from gelling in cold weather.
/ Need INJECTION PUMP ASSEMBLY KIOTI CK30 #5
He's in Louisiana, doubt he has gelled fuel...
/ Need INJECTION PUMP ASSEMBLY KIOTI CK30 #6
Seems like a logical assumption. However during our conversation, he said it got down to 12 when his tractor quit. Now grant it, louisiana is one of the last place you would think of gelling and one of the last place probably selling winter fuel. Summer fuel and 12 degrees makes a good recipe for gelling and plugging up the fuel filter. Don't take much to find out. It is now in the 60's. Put a new fuel filter on and if the cold weather go him, then problem solved and tractor should run. I get it, if somebody in Louisiana told me they gelled up, I'd look at them like they had two heads. Under the circumstances I'd put a new fuel filter on and eliinnate the possibility.
/ Need INJECTION PUMP ASSEMBLY KIOTI CK30 #7
The ck30 has a history of pump problems ,there are 3 plastic gears that strip . they only strip on 1 side and usually only 1 strips . Any good mechanic can take it apart and replace the gears or do as I did ,I marked each one 1,2,3 and turned them 180° putting the center one at 1 or 3 .the gears have splines on both sides but the rack but only use one side .if you switch them like this you could theoretically use the original gears to repair it 4 more times . Install a cable shut off and the gears would last 50 years .
/ Need INJECTION PUMP ASSEMBLY KIOTI CK30 #9
Sam, I emailed you last Friday but I just noticed I put bs.COM.. instead of NET.. forwarding the info now.
2021 FORD F-150 STX CREW CAB TRUCK (A59823)
2021 FORD F-150...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
John Deere HX20 (A60462)
John Deere HX20...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
Giyi-D39 QA Trencher (A60463)
Giyi-D39 QA...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
