Backhoe Need info on parts for Mahindra 4550B Backhoe
   / Need info on parts for Mahindra 4550B Backhoe
It seems very possible, we could not get it loosened. I ordered a gland tool yesterday and plan on pulling the gland and piston out so I can clean the tube out. Some may say I'm being OCD, but I drilled on it before engaging the brain and want to be sure I am not going to have metal shavings left in there to eat away at the seals. Nothing worse than being in the middle of a project and that short-cut you took 6 months ago coming back to bite you in the hindparts.
You can try New England Tractor and then go to Mahindra parts (might need to do it twice) and then use the model search feature, once that comes up type in 4550b and hit enter.
NEW ENGLAND TRACTOR a division of Johnson Automotive Inc.
Looking at their site now, seems like the most comprehensive parts sites for Mahindra dealers without having to call their physical location. I see an option for manuals and that they list each the operator's, service and parts manuals. I had previously search for a true service manual and only had luck on ebay at around $200, New England Tractor has it for $82. Curious if anyone has this one and if it is more service than operators manual? I had read about another large dealer selling operator manuals as service/maintenance manuals previously. Something with tolerances, torque specs, etc. would be nice and the parts manual even more so.
   / Need info on parts for Mahindra 4550B Backhoe #13
......pulling the gland and piston out so I can clean the tube out
By far the better way to do it. Be sure to let us know how you make out......Mike
   / Need info on parts for Mahindra 4550B Backhoe #14
The only thing that I ever ordered from New England Tractor was lube for the 4540, I had two tubes left but wanted more in inventory and my local dealer didn't have any lube in stock for three weeks. I don't think my local dealer liked it when I said you'll sell me a tractor but you don't have lube in your inventory.
I ended up ordering a case of lube from New England Tractor, great people to deal with and he was very nice while talking with him on the phone before I ordered.
So far not so good, got my tools in and either the gland is torqued pretty extreme or they used an adhesive. Going to call NET and price a rebuild kit in case I have to heat it. very tempted to clean up the end of the elbow and have a fitting welded on and run with it.
Just got off the phone with New England Tractor, they could not locate a part number for rebuild kit and couldn't say if Ansung (or whoever supplied the cylinder to Ansung) used an adhesive on the gland or not. Stated that ordering individual seals and o-rings could take weeks to months to get from Korea. Called the dealer I purchased the tractor from originally to speak with their lead mechanic (he's out sick today) as he had rebuilt the boom cylinder previously, and ask him if they had to heat it or not. Getting really tempted to purchase a fitting get it welded on and run with it. Other option is taking it to a local hydraulic repair shop.
   / Need info on parts for Mahindra 4550B Backhoe #17
That sucks try the local hydraulic shop and get a quote might not be that bad
   / Need info on parts for Mahindra 4550B Backhoe #18
That sucks. try the local hydraulic shop and get a quote might not be that bad
I'm thinking along the same lines. Chances are it's a standard seal size, can't see why it'd be an oddball but.....you never know.Get a quote on them rebuilding it and just ask them to call you when they have it apart, go get it, weld a coupling over the removed busted fitting port and take it back to them. Ask what they'd want to do the complete job, may not be worth the aggravation of even looking at it.................Mike
Thinking along this line myself. Sucks paying to rebuild a cylinder that shows no sign of needing a rebuild, but spending more money trying to save money makes no sense either...
   / Need info on parts for Mahindra 4550B Backhoe #20
If you're concerned about crap in the cylinder you could cut that fitting off and stick a piece of hose over it then use the cylinder to draw in hydraulic oil and then push the cylinder again to flush the oil out. You could do that a few times and maybe you'd get any crap out of it.
Alternatively as others have suggested, a hydraulic shop could do the whole job for you at a pretty reasonably price. You could have them take it apart, check the seals, clean it out, and weld on the fitting. They should be able to do it all.
UNUSED Artificial Turf Grass (A53117)
UNUSED Artificial...
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
GENERAL GENERATOR (A55745)
GENERAL GENERATOR...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
