Need info on my Ford 3400 project
   / Need info on my Ford 3400 project #11
C5012K
C 3000 ( 4-1968 OR LATER )
50 INDUSTRIAL CHASSIE
1 DIESEL
2 TRANS 540 PTO
K 6/4 MANUAL REVERSING TRANSMISSION
2K31B
2 1972
K OCTOBER
31 OCTOBER 31
B DAY SHIFT
I'll send the fax this am.. It will have a generic cover sheet from my day job, John L Finch Contracting Corp.
in case the part numbers on the diagram don't come thru good, I think the important ones for you to look at are: ( though there may be others once you get it torn down )
49, 50, 51, 45, 44, 46, 47 front axle bushings
57, 53, 56 spindle bushings and seal
the parts list page is pretty legible so should go thru fine. if not, email me.
hope it helps
Soundguy
   / Need info on my Ford 3400 project #12
Hey I don't know what that could be.My dad has a '67 model 3400 and we have trouble with the power steering.It leaks terribly after sitting about a day and sometimes it will squirt fluid up around the steering wheel.Has yours ever done this?We've replaced the seal in the column several times and also replaced some of the plungers and springs in the steering unit.This doesn't seem to fix the problem.Any in fo would be appreciated.
   / Need info on my Ford 3400 project #13
Where specifically, other than the column is it leaking?
Soundguy
2005 OTTAWA T2 YARD SPOTTER (A51222)
2005 OTTAWA T2...
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
2021 Isuzu NRR (A50323)
2021 Isuzu NRR...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2013 MACK PINNACLE CHU613 DAY CAB (A50854)
2013 MACK PINNACLE...
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
