Need info on Ford Model DL123C
/ Need info on Ford Model DL123C #1
rewilmes
I recently purchased a Ford tractor with an integrated trencher on the back and a loader on the front. The Model number is DL 123 C and the Tractor number is C489195.
It is yellow and has low profile tires, a 3 cylinder gas engine and a 6 foreward, 2 reverse transmission.
I need to repair the power steering but I have been unable to find the model number on the internet.
It looks like a 335 but i'm not sure about parts.
Any help is appreciated.
/ Need info on Ford Model DL123C #2
i would say it would be a 3400 are 3500 does it have two cylinders one on each side if so it is a 3400 style if not it has the 3500 style steering which is a rod running down the left side of the motor go into the front end where a cylinder is located a picture would help alot and what is wrong with the power steering
/ Need info on Ford Model DL123C #3
Look on the flat area of the bell housing above the starter (see pic) and get the 3 groups of numbers. They will be similar to the ones in the pic. Your Ford/NH dealer should be able to tell you exactly what you have. There are probably several people on here that can do that also. I'm at my day job right now. I'll look when I get home and see if I can find anything else.
Mike
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR3BJ325816 (A61165)
2011 International...
2016 Case CX55B Midi Excavator (A60352)
2016 Case CX55B...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
2013 GREAT DANE  TANDEM AXLE 48FT DRY VAN TRAILER W/CRANE (A59909)
2013 GREAT DANE...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
