need info on ford 8600
   / need info on ford 8600 #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I may ride out to look at a ford 8600 with a buddy of mine.
Any info I can pass along. I'm not at all familiar with an 8600. ( though have done a bit of research on the 8000.. etc. ) I hear this unit has an 8spd.. etc, and is a 6cyl.
Any info available is appreciated, including pro/con, problem areas, and advice / priceing. etc. I'm just their for moral support.. but wouldn't mind being armed with a fact or two.
Soundguy
   / need info on ford 8600 #2
If I recall, some of the 8600's had dual power which is a great feature (does your 7610s have DP?). As for any issues, most of the 8600's I see now have been beat hard. Just look it over carefully if it has new paint on it and take it for a ride to see how it runs. I have been looking for an old 86/8700 or 96/9700 to add as a tillage tractor but so far all of the 8600's I have found are priced way too high for their condition. Have fun.
Pain it not good. I guess the steering motor needs to be checked.
Suposedly no dual power.
( no my 7610s has no dp.. just 8spd... which i like... the 8spds seem pretty solid. ).
Soundguy
   / need info on ford 8600 #4
Check the steering cyclinder in front of the radiator for leaks and a loose piviot bearing. Big problem area and parts are NLA. These tractors also had a big problem with shift linkage hanging up and not shifting. Also look at the remote valves for leakage, they are mounted on the right hand pump cover. We service a lot of this model tractor, personaly I would not own one as I do not need another job. The internals of these tractors are great but the external parts are a mess.
Thanks for the info, I'll pass it on.
PS
I looked at a 72 ford 5000 RC today. It's a much different beast than my 75 utility chassie 5000. Different op platform, and power steering setup.. dash and some other doo dads.. etc. I much prefer the utility chassie....
Soundguy
   / need info on ford 8600 #6
That Saginaw steering gear was a little too "sophisticated"?
2016 TROXELL 130BBL VAC TRAILER (A52472)
2016 TROXELL...
2017 Ford Expedition 4x4 SUV (A50324)
2017 Ford...
2012 Ram 1500 Crew Cab Pickup Truck (A50323)
2012 Ram 1500 Crew...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2015 Peterbilt 320 Heil Front Loader Garbage Truck (A50323)
2015 Peterbilt 320...
