Backhoe need info mounting a woods 750 hoe on a MF 1260
   / need info mounting a woods 750 hoe on a MF 1260 #1
chasmor
white deer, PA
MF 1260
I have a MF 1260 bought new in the 90's and recently bought a used woods 750 back hoe, that is mounted on a sub frame... the seller thought it was from a mihindra, but didn't know... I do know the frame doesn't match my tractor and from previously reading here using it on the 3 pt isn't the best way to go. I contacted woods and they don't sell a kit anymore. I would like to make or purchase the mounting hardware that fits to the tractor,( or at least know where the mounting pts are?) I will then modify the frame to fit. Any input, pics, or place to find more info would be appreciated. Thanx Chuck
   / need info mounting a woods 750 hoe on a MF 1260 #2
Hi Chuck, I built a sub frame for my 3 pt hitch hoe out of 2x3 tubing to fit my 1440 Massey. On my 1440 I built 2 brackets out of 1/2" flat bar and mounted under the rear axle. I replaced the factory bolts with 1/2" longer ones. The bracket was like an upside down U and slid over the sub frame and was pinned. For the front of the sub frame I made brackets to pin into two eyes that are on the bottom of my loader frame 3/4" hole. I am not sure if your 1260 is the same as I can not remember if my 1250 had them.
Good Luck
Frank
Good Luck
Frank
Frank, thanks for the reply... is there any chance I could get a picture of what you made? on the front of the tractor the loader mounts are very forward, but I saw threaded holes in the tranny... 2 on each side... thinking this may be a mounting place although not sure what forces it will take? it looks like I could do the same on the back axle but would have to space down a little. I may make a trip to dealer and ask where they are to be mounted.. thanks
   / need info mounting a woods 750 hoe on a MF 1260 #4
Here are a couple of pics, 2 of the front loader brackets and one of the rear U brackets that I built and mounted under the axle. If you would like a pic of the sub frame, I will have to move some stuff! :) I do not use it anymore. I picked up a gc2610 TLB and got rid of my 3pt backhoe for my 1440. Hope this helps. :)
thanks for the pics.. questions ??'s assume on the front the side to side play of the subframe is minimal and there is either a long rod or bolts on both sides to secure? on the back I assume ( a thing I hate to do) again, your subframe box beam goes into the brackets and you put a bolt or pin below it to secure? 3/4" ? enough? I don't believe I'll need a pic of the sub frame at this time... and I will need to reevaluate the FEL mounting again this weekend... Thanks Chuck
   / need info mounting a woods 750 hoe on a MF 1260 #6
There was very little side play in the front, The sub frame has 2 flat bar tabs per loader bracket with 3/4" hole through them.(similar to rear brackets only smaller ) I used 3/4" draw bolts and clips to attach it. On the back, the sub frame slid up inside the brackets under the axle with about 3/8" clearance on the sides.(3/16 per side of bracket) I used 7/8" draw pins in the back.
When all 4 pins were in, it did not move very much.
thanks this should give me a direction to head... 1 thing I noticed on my hoe was it appears to have the safe tee link attached also, which I thought was for the 3 pt mounting.... but the hoe is pinned to the subframe similar to the lower part of a 3 pt hitch? which would make it pivot here without the upper link in place.. I'm going to check and see if I can alter the subframe and bolt it securely, like I noticed in 1 of the woods manuals for a different model....
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
Mccormick Hammer Mill (A57454)
Mccormick Hammer...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2016 Chevrolet Traverse SUV (A56859)
2016 Chevrolet...
Valve Grinder Set (A57454)
Valve Grinder Set...
2026 14 ft Quality Steel 7 Ton T/A Dump Trailer (A56858)
2026 14 ft Quality...
