Need info/experience on Mulching head skidsteers....
   / Need info/experience on Mulching head skidsteers.... #1
BobG_in_VA
Central VA, USA
Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
Folks, does anyone have good info on the tracked mulchers??/ I'm looking at clearing about 5 acres of land that is now wooded (it was timbered about 27 years ago). The trees are pretty much 20-25 feet tall and from 3" to 8" in diameter. Will one of these units actually capable to do the job without taking a whole bunch of time?? The contractor says they get $1500/day (8 hr days) and can clear about an acre a day (I've seen videos of clearing undergrowth and small 4" or so saplings--one at a time)...I don't want to start and then find out it can't cut it (literally and figuratively). Good Info Needed!! BobG in VA
   / Need info/experience on Mulching head skidsteers.... #3
a lot depends on the type of machine they are proposing on using...and what is the tree type? Hardwood vs. softwood makes a big difference. Also density of stems...if the majority of wood is 6" or greater, I would think that shearing/bunching and skidding to a chipper might be a better bet...with 20-25 ft of 6-8" trees (especially hardwood) creates a lot of mulch...also depends on what you plan on using the area for after...if you are thinking of seeding the area for grass or something else, then getting all the bio-mass (mulch) off site might make more sense...
so to give my two cents worth- it all depends...
(1) VISSANI REFRIGERATOR (1) FRIGIDAIRE REFRIGERAT (A51248)
(1) VISSANI...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
1271 (A50490)
1271 (A50490)
2018 Seal Rite SR 700XP Seal Trailer (A52384)
2018 Seal Rite SR...
UNUSED FUTURE SF60 HYD MAST W/ 60" FORKS (A51248)
UNUSED FUTURE SF60...
