Need ideas - sliding doors and birds
   / Need ideas - sliding doors and birds #21
Well, you have to know these things when your a king, you know...
Listen. In order to maintain air-speed velocity, a swallow needs to beat its wings forty-three times every second, right?
Steve
   / Need ideas - sliding doors and birds #23
It seams a lot faster when they are dive-bombing for bugs under a street light.
   / Need ideas - sliding doors and birds #25
I think you might be able to buy bristle like in a push broom in long single strips. Then screw them to the overhang trim. I have seen them but would not know where even start to look.
   / Need ideas - sliding doors and birds #27
I will be interested in the responses. I don't have any personal experience, but some claim that owl decoys will scare off birds. I am contemplating buying a couple of decoys to deter birds from nesting in a couple of my sheds. Steve
They have my barn a mess. Piles of poop! I tried the owl decoy. Seemed to help a little a cpl days only. Even then tied metal pie pan to bottom as a spinner. Suspended all this from a beam in loft. It's floating and looks intimidating enough. I think it even has poop on it now too.
I'll be checking thread to see if anyone succeeds.
   / Need ideas - sliding doors and birds #28
Ps.. If there's just one point where they're coming in, there's a product called
" sticky foot". Birds hate it. It's applied with a caulking gun.
   / Need ideas - sliding doors and birds #29
Did post in the wrong place, if so I well delete.
To those who mentioned owls and other type deterrents I know first hand that they do not work long term. This kind of situation requires something different. I did some research and found that the most effective solution to stop birds from roosting was spikes. You can buy strips of them in plastic (cheap) or stainless steel. They are generally cross angled and I'm sure do a good job but they are meant to install on surfaces that are completely open. The spikes are typically 4 inches long or more and would not fit on top of my doors without being trimmed. Additionally, the doors would have to be removed from the track, at least partially, to install these 1 foot strips. But the spikes gave me an idea that I hope will solve my problem. There is about a 1 inch gap between the top of my doors and the bottom of the header (see the pictures). And the space in there is about 2 1/2 inches high by about 4 inches wide, so birds have plenty of room to roost but their tail, and butt, point inside. Someone in this thread mentioned that their sheet metal shroud covering the track is bent down very close so birds cannot get underneath it. However, my shroud is held in place by preformed clips so I cannot just bend my shroud down. I had some left over aluminum trim stock so I figured out a design that would take up that space and, hopefully, solve my problem. The aluminum trim stock is easy to cut (just score with a utility blade and bend), easy to bend with clamping wood on it, and will never rust or corrode. And I installed it from the inside without having to mess with taking the doors off. The short pieces at the end of each door were only 10 inches wide and easy to make. The center section of the doors, between hangers, was 58 inches so I decided to make 2 pieces to cover that length which was much easier to deal with. My trim pieces were 9 inches wide to start, then bent almost in half (one side 1/2 inch longer) and then rebent to form the appropriate angles as shown. Hopefully, this will give all of you with the same problem some ideas and make something like this work for you. For those of you who temporarily hijacked this thread - thanks for all the interesting swallow information. ;-)
NEW HOLLAND 3930 TURBO TRACTOR (A54756)
NEW HOLLAND 3930...
2015 Ford F-350 4x4 Cab and Chassis Truck (A55788)
2015 Ford F-350...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A54757)
UNUSED RAYTREE...
UNUSED RAYTREE RMBD50 - 50" DRUM MULCHER (A54757)
UNUSED RAYTREE...
UNUSED LANDHONOR 5/16" 7' G80 DBL CHAIN SLINGS (A54757)
UNUSED LANDHONOR...
