Need ideas prepping for winter
   / Need ideas prepping for winter #1
fred.hayfarm
New Holland TC29D
I am a new owner, new to tractors, new to hydraulics, and new to diesel. I have a New Holland TC29D with 400 hours. I would like to use it this winter for snow removal and I have two concerns: hydraulics and diesel (should I have others?)
How should I prepare for operating in temps from 0-30? Should I change the hydraulic oil. Is this a DIY or pro job? I had a full change at 350 hours, so I will be throwing away a lot of good oil.
When should I switch over diesel from #2 to #1? Do I have to drain the existing fuel, or can I blend it as the temp drops? I am getting summer fuel from my neighborhood gas station. Is this a good source for winter grade, or should I go to some other source? If so, what would that be?
Any advice beyond this would be most appreciated.
Thanks,
Fred
   / Need ideas prepping for winter #2
No need to change anything hydraulic wise
Just treat the normal #2 and you will be good to go
   / Need ideas prepping for winter #3
You have about the same temp range as us in winter. (0-30f)
I run Delvac one synthetic. You want an oil that is thin when cold. Use a winter motor oil. The hydraulic oil is fine as mentioned above.
I add Howse diesel treat to keep from gelling. There are other additives for that purpose too.
I plug in the block heater for a few hours. It starts much happier that way. Then I let it warm for about five minutes.
1200 hours and around 25 years on the 1910 and still running great.
   / Need ideas prepping for winter #4
I treat my leftover summer fuel in the fall. Plug in the block heater before I start.
Welcome to TBN Fred.
   / Need ideas prepping for winter #6
Thanks,
Fred
Read my Post on the fuel subject.
Thanks for all the info. I have enough leads to keep me busy until fall.
Thanks again,
Fred
2006 International 7400 Dump Truck (A47477)
2006 International...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
Brent 420 Grain Cart (A53473)
Brent 420 Grain...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
