Need ideas prepping for winter
/ Need ideas prepping for winter #1
fred.hayfarm
New Holland TC29D
I am a new owner, new to tractors, new to hydraulics, and new to diesel. I have a New Holland TC29D with 400 hours. I would like to use it this winter for snow removal and I have two concerns: hydraulics and diesel (should I have others?)
How should I prepare for operating in temps from 0-30? Should I change the hydraulic oil. Is this a DIY or pro job? I had a full change at 350 hours, so I will be throwing away a lot of good oil.
When should I switch over diesel from #2 to #1? Do I have to drain the existing fuel, or can I blend it as the temp drops? I am getting summer fuel from my neighborhood gas station. Is this a good source for winter grade, or should I go to some other source? If so, what would that be?
Any advice beyond this would be most appreciated.
Thanks,
Fred
/ Need ideas prepping for winter #2
No need to change anything hydraulic wise
Just treat the normal #2 and you will be good to go
/ Need ideas prepping for winter #3
You have about the same temp range as us in winter. (0-30f)
I run Delvac one synthetic. You want an oil that is thin when cold. Use a winter motor oil. The hydraulic oil is fine as mentioned above.
I add Howse diesel treat to keep from gelling. There are other additives for that purpose too.
I plug in the block heater for a few hours. It starts much happier that way. Then I let it warm for about five minutes.
1200 hours and around 25 years on the 1910 and still running great.
/ Need ideas prepping for winter #4
I treat my leftover summer fuel in the fall. Plug in the block heater before I start.
Welcome to TBN Fred.
/ Need ideas prepping for winter #6
Thanks,
Fred
Read my Post on the fuel subject.
Thanks for all the info. I have enough leads to keep me busy until fall.
Thanks again,
Fred
UNUSED (4) 295/75R22.5 TIRES & ALUMINUM RIMS (A63745)
UNUSED (4)...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
KBH Tender (A63118)
KBH Tender (A63118)
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
