Need hydraulic oil for a Homelite Electric log splitter (Model#Ut-49103)
   / Need hydraulic oil for a Homelite Electric log splitter (Model#Ut-49103) #1
Joebklyn
I was just gifted an old log splitter. It needs a hydraulic oil change. The owners manual does not say what type or kind of hydraulic oil. Can anybody tell me what to put in this thing? Thanks1
   / Need hydraulic oil for a Homelite Electric log splitter (Model#Ut-49103) #2
Nothing special. It's maybe more a question of what sources you have.
Home Depot/Walmart/Advance Auto there are quite a few places and I've noticed quite a few diffrent kinds of hydraulic oil. Can you recommend which type I'm to use?
   / Need hydraulic oil for a Homelite Electric log splitter (Model#Ut-49103) #4
The tractor supply brand fluid that was on sale last Friday for $16 for 5 gallons would have been great...
   / Need hydraulic oil for a Homelite Electric log splitter (Model#Ut-49103) #5
And unless it has water or other contaminates in it I wouldn’t even bother.
   / Need hydraulic oil for a Homelite Electric log splitter (Model#Ut-49103) #7
How much is the pump vs the oil cost? Say it’s stupid all you want but have you ever heard of a wood splitter failure caused by bad oil.
   / Need hydraulic oil for a Homelite Electric log splitter (Model#Ut-49103) #8
If the oil is clean and amber color there is no reason to change it. If not, any name brand AW32 hydraulic oil should do fine. I would not break the bank on the fluid. It is just going through a tank, pump, valve, cylinder and filter. Nothing there is hard on fluid.
   / Need hydraulic oil for a Homelite Electric log splitter (Model#Ut-49103) #9
Would regular automotive transmission fluid work?
   / Need hydraulic oil for a Homelite Electric log splitter (Model#Ut-49103) #10
These are low tech systems much simpler than equipment so it probably would work, but why wouldn’t you use hydraulic oil? Which is cheaper anyway.
New/Unused Self Dumping Hopper (A44391)
New/Unused Self...
2009 Ford F-350 Crew Cab Pickup Truck (A42744)
2009 Ford F-350...
2014 WESTERN STAR 4900 SF (A45333)
2014 WESTERN STAR...
2012 CONVEY-ALL  SK-4000 SAND KING TRAILER (A45333)
2012 CONVEY-ALL...
2016 Ram 1500 Pickup Truck, VIN # 1C6RR7XTXGS346729 (A44391)
2016 Ram 1500...
2004 INTERNATIONAL 9400I (A45046)
2004 INTERNATIONAL...
