Need HTML refresher in CSS
/ Need HTML refresher in CSS #1
PineRidge
Super Member
Northeast, Ohio
LS-MT242HC
Need to enlist all you HTML Grus :)
I'm re-designing our home page to get better rankings within the various search engines.
I am aware that the majority of search engines give a boost in relevancy to words placed within the <H1> tags. They associate the <H1> tag to specify page or topic headings.
Problem is that the words are just to large to suit my taste.
So, would like to use a cascading style sheet (CSS) to specify to the browser to display whatever font size I need for the <H1> tag. Make sense?
So I inserted the following code on our home page:
<link href="http://www.pineridge7.com/firststyle.css" rel="stylesheet" type="text/css">
Then I made a new page called firststyle.css and loaded it in our web (root directory) with the following code:
h1 {font-family: Arial, Helvetica, sans-serif; font-size: 14px; color: #000099;}
I assumed (there's that word again folks) that it would make the <H1> heading and display it as a 14 point font size, but there is no change that I can see in IE. Why?
If you would like to view the source code please go here:
www.pineridge7.com
As always, thanks for your input guys!
/ Need HTML refresher in CSS #2
Mike,
I ran your code through an online css validator at http://validator.w3.org/ and it passed.
I then looked at your page referenced above and did a "view source". The first line it showed was the <body> tag. There was no <head> section, which is where the link to the css file needs to be. Did I miss something?
Frank don't think that's it. I changed the tag but it's still not working. Funny in in Front Page view it appears to have reduced the print, but when published it still looks full size.
/ Need HTML refresher in CSS #4
Mike,
I took a look at your page and it appears there is a problem with the title or header, whatever it's called.
/ Need HTML refresher in CSS #5
Here is some samle code from my website:
<html>
<link rel="stylesheet" type="text/css" href="stylesheet.css" />
<link rel="stylesheet" type="text/css" href="stylesheet-print.css" media="print" />
<link rel="Shortcut Icon" type="image/ico" href="images/icons/favicon.ico">
<head>
<title>All in the Picture - Weddings</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
Please note that the stylesheet.css file is in the same directory as the file calling the css file.
Here is s the CSS file. "stylesheet.css"
body { font-family: Georgia, "Times New Roman", Times, serif;
font-size: 12px;
margin: 0px 0px 0px 0px;
padding: 0px 0px 0px 0px;
color: #333;
p {
font-size: 16px;
h3, h4 {
color: 000080;
font-size: 18px;
font-style: normal;
h1 {
color: #000080;
font-size: 30px;
font-weight: bold;
text-transform: uppercase;
h2 {color: #000080;}
h6 {font-family: Georgia, "Times New Roman", Times, serif;
font-size: 16px;
color: 000080;
a {color: #000080;
text-decoration: none;
font-weight: bold;
a:hover {color: #000080;
text-decoration: underline;
font-weight: bold;
li, td { font-family: Georgia, "Times New Roman", Times, serif;
font-size: 16px;
color: #333;
.sectiontitle {
color:#333;
font-size:small;
font-weight:normal;
padding:9px;
margin-bottom:8px;
background:#eee;
text-transform:none;
.blogbody { font-family: helvetica, arial, sans-serif;
font-size: 10px;
color: #333;
.advertisement {
background-color: #FF0000;
padding: 9px;
font-family: Arial;
font-weight: normal;
color: #FFFFFF;
.advertisement2 {
background-color: #FFFFCC;
padding: 9px;
font-weight: bold;
color: #333333;
font-variant: small-caps;
font-style: italic;
font-size: 24px;
text-align: center;
.referral {
padding: 7px;
h5 {
font-size: 10px;
font-style: normal;
color: #000080;
hr {
height:2px;
background-color: #000080;
width: 700px;
background-position: center;
.pdf {
font-size: 14px;
font-style: normal;
font-weight: bold;
color: #FFFFFF;
background-color: #CCCCCC;
padding-top: 8px;
padding-right: 8px;
padding-bottom: 8px;
padding-left: 8px;
I hope that will lead you in the right direction.
Derek
Inspector507 said:
Mike,
After your comment I made a test page using Front Page click here
After uploading it everything worked. So I started comparing the tags between the two pages. You guys were right I had the tags messed up a bit. I also had the:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
stripped out of the page.
All appears to be working correctly now, thanks for your help guys!
/ Need HTML refresher in CSS #7
CSS is a great tool. I use it for all of my client's sites now (I do web design and programming on the side). When they get a wild hair and want to change how the site looks, I simply change a couple of lines of code and viola! Everything looks different. Saves tons of time.
/ Need HTML refresher in CSS #8
I don't believe that's the case. That may just be one of hundreds of methods used.
Gaterboy it may or may not be the case, I'm really not the expert on this subject by any means. But when I read something in print I normally don't have a reason to challenge it. Good thing for all my past teachers!
/ Need HTML refresher in CSS #11
Well I don't use any <h#> tags and I'm listed very well with Google. Try and get linked from other sites -- that's one of the better ways to get higher rankings.
Your <title> is important as well as the text early on in your page. There are many ways to get listed high -- don't put all your eggs into the <h#> thing.
Good suggestion Bones. And thanks for the compliment.
/ Need HTML refresher in CSS #15
In short PageRank is a “vote”, by all the other pages on the Web, about how important a page is. PageRank is a numeric value that represents how important a page is on the web. Google figures that when one page links to another page, it is effectively casting a vote for the other page. The more votes that are cast for a page, the more important the page must be. Also, the importance of the page that is casting the vote determines how important the vote itself is. Google calculates a page's importance from the votes cast for it. How important each vote is is taken into account when a page's PageRank is calculated. On a scale of 1-10, your home page is a 4 which is quite good.I have a few that are 3's and 4's but only after a year and much tweaking.You can check pagerank here if you don't want to d/l the Google toolbar.http://www.phplivesupport.com/google_pagerank.php
In comparison, Tractorbynet.com has a PR of 5.Your'e doing good.
Thanks for the interesting info. I've been tweaking things a bit to get the rankings up but changes take 6-8 weeks to re-index in the engines. We'll keep our fingers crossed and see what happens.
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
10in Digging Tooth Bucket Excavator Attachment (A64194)
10in Digging Tooth...
1998 Fontaine 48ft. 38 Ton T/A Flatbed Trailer (A61573)
1998 Fontaine...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
2015 ISUZU NPR 4X2 16FT BOX TRUCK (A59912)
2015 ISUZU NPR 4X2...
