Need High Lift Blades for new JD x380
   / Need High Lift Blades for new JD x380 #1
Johnkn
Platinum Member
Laplata, MD
Kubota LX3310
Anyone recommend any quality aftermarket high lift blades for a new John Deere x380? While JD makes other high lift bladed, apparently they don't make them for the 48" Accel deck. thanks
   / Need High Lift Blades for new JD x380 #2
I would check to see if blades made by Oregon are available for your JD. I have always found Oregon to be a good quality blade. Hope that helps.
   / Need High Lift Blades for new JD x380 #3
I've been very impressed with the aftermarket "Predator" blades on my D110. A nice 'wing' tip for lifting not only grass for cutting but also picking up horse manure balls for mulching.
I installed them about 4 months ago.
   / Need High Lift Blades for new JD x380 #4
John what is the reason you are looking for the high lift blades?
are you having discharge issues? the claim to fame for that new deck
is cut quality and discharge performance, so i'm curious to know
why you are asking for different blades..
are you using the mulch control system?
   / Need High Lift Blades for new JD x380 #5
I only mention this because I think it a bit humorous. I thought some high lift blades would be the ticket for my JD 325, 48 mower. Turned out to be a dry summer and all those blades did was stir up a huge dust cloud (cough, cough, LOL). Went back to standard blades.:laughing:
1998 FORD F-800 22FT BOX TRUCK (A43000)
1998 FORD F-800...
TBD 16 FT UTILITY TRAILER (A45333)
TBD 16 FT UTILITY...
NEW 1" AIR IMPACT WRENCH 1900 FT/ LB NEW SUPPORT EQUIPMENT (A40018)
NEW 1" AIR IMPACT...
Liebherr LR 621B (A42021)
Liebherr LR 621B...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A42744)
2016 Ford F-150...
CAT BA25 Hydraulic Angle Broom (A42021)
CAT BA25 Hydraulic...
