Need help
/ Need help #1
ben21921
Elkton, Maryland
none/ yet
Have a fairly new LS xr3037 H I was getting ready to mow so I took the bucket off and after I took the bucket off the front end loader will not raise or lower it will tilt and curl fine but something feels like it's stuck when I try to raise or lower it any suggestions?
/ Need help #2
In front of the joy stick, there is a little silver tab that you can push in to lock out the stick. check to see if you hit it by accident. Pull hard on it to get it to unlock. I did it to mine when it was new.
George
/ Need help #3
Sorry, I was wrong. I went out and checked my XR3135HC, and it is not the little tab, your joystick has gotten pushed forward into float position, pull back hard on the stick and it will snap back to where it should be. When new they snap hard or stick
George
/ Need help
That was it thanks so much. I read that in the Manuel but your right I really had to pull hard. Thank you
White Oak Boards (A65640)
White Oak Boards...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
7' Barnwood Bar Table (A66408)
7' Barnwood Bar...
New/Unused CFG Industrial H12R Mini Excavator (A65579)
New/Unused CFG...
